Old 09-28-2007, 11:56 PM   #1
WorkinLonghorn
WorkinLonghorn's Avatar
Lubbing the peddle shaft
Mine has been squeaking real bad for years and I've never seen a proceedure for getting some grease up there.Clutch and brake share one shaft but I thought there'd be a zerk fitting/Don't see one.Do I have to remove the shaft to grease it? And "if" I need bushings,is that an easy job? Thanks!
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 09-28-2007, 11:58 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Lubbing the peddle shaft
Can you say that on here? Sorry, but I couldn't resist...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-29-2007, 01:22 AM   #3
dan42
dan42's Avatar
I lub my wife and my truck, and I even lub my dog - don't lub my clutch/ brake shaft though. Might lube it once in a while. I would think a good squirt of WD40 would work -something that would get in there without having to take it apart.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 09-29-2007, 03:17 AM   #4
oldschooler
oldschooler's Avatar
ive been looking for lub in all the wrong places
oldschooler is offline   Reply With Quote
Old 09-29-2007, 06:38 AM   #5
cdowns
cdowns's Avatar
what i'd try would be to spray real good with wd-40 while working the pedals no lubricating value but will clean out crap then using spray white lithium grease for the actual lubrication
Old 09-29-2007, 06:51 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
there are no bushings in there. the metal shaft rides in the plastic firewall mount.
where as the clutch and brake do have replaceable bushings which can still be gotten from the dealer for like $.25 each.
68C15 is offline   Reply With Quote
Old 09-29-2007, 10:01 AM   #7
WorkinLonghorn
Thanks,that's what I'm talking about;When I push the clutch peddle I get a loud squeak.
I've tried shooting wd40 up there and it seems to help for awhile,then it comes back.Guess I'll just splurge and get those two bushings and do 'er up right.
To some of you guys above ; I lub bushings.
Old 09-29-2007, 12:12 PM   #8
prg machine
prg machine's Avatar
""" ......All ya need is LUB..............dant da danta dah""""
WD is worthless in the machinery world. It only gums up stuff, atracts dust and dirt. Use a good aerosol lubbe like Gibbs.
www.gibbslubricant.com:)
prg machine is offline   Reply With Quote
Old 09-29-2007, 04:25 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I think I would miss the squeak.I've had three of these trucks as daily drivers and they all have the same squeak.I don't even know if I would be comfortable driving an auto since it wouldn't have the clutch squeak.
I lub my wife and dog and lube my column shifter.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-29-2007, 09:14 PM   #10
prg machine
Gotta LUB it!!!
