Old 09-28-2007, 09:32 PM   #1
jorgensensc
jorgensensc's Avatar
Changing To gauge cluster.. Where is the wiring FAQ?
He y all, I'm changing out to a gauge cluster and can't find the FAQ that said how to change the harness connector. Can someone locate it for me. I can't seem to find it in the FAQ's, but maybe I missed it. Iknow we have one, unless I'm
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-29-2007, 01:16 AM   #2
Bob Moore
Re: Changing To gauge cluster.. Where is the wiring FAQ?
One place to start is at GMC Paul's technical area showing the conversion from lights to gauges. Lists the dash plug terminals by number and color if I recall.
Hope this helps - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 09-29-2007, 03:55 AM   #3
72armyswbtruck
72armyswbtruck's Avatar
Try this link
http://www.gmcpauls.com/Tech%20Tips1.htm
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-29-2007, 07:46 AM   #4
gotchevys?
gotchevys?'s Avatar
Mabye this could help also.
http://67-72chevytrucks.com/vboard/s...d.php?t=185665
www.fatdaddieshotrods.com
gotchevys? is offline   Reply With Quote
Old 09-29-2007, 08:27 AM   #5
jorgensensc
perfect guys! Exactly what I was Looking for! Thanks!
SHawn
