Old 09-28-2007, 06:00 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Cutting 1/4" plate...
What are you guys using to cut your plate and pipe? Grinder/cut-off wheel seems like it would take forever...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-28-2007, 06:20 PM   #2
abadsvt
abadsvt's Avatar
Re: Cutting 1/4" plate...
I use a plasma cutter. It makes life alot easier. I think you might be able to rent them. If you have alot to cut i would highly recommend it. Cut off wheels work but i have broken alot of them when they get binded up and break so i try not to use them unless i need to.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 09-28-2007, 07:21 PM   #3
naynay
i'd use plasma or oxy acetylene
naynay is offline   Reply With Quote
Old 09-28-2007, 07:40 PM   #4
mudmilitia
mudmilitia's Avatar
Porta bandsaw
mudmilitia is offline   Reply With Quote
Old 09-28-2007, 08:47 PM   #5
cdowns
cdowns's Avatar
i've used a cheapass jijsaw with excellent finetooth bimetal blades with good lubrication for the past 40some years dont think of anything else
Old 09-28-2007, 11:43 PM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
I did my c-notch work on my truck with cut off wheels and a jig saw. 1/4" steel was not too hard to cut .
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 09-29-2007, 12:12 AM   #7
bigbluthng
bigbluthng's Avatar
vise, sawzall and "the torch" blades for 1/4" metal
bigbluthng is offline   Reply With Quote
Old 09-29-2007, 12:45 AM   #8
Shane
Shane's Avatar
jig saw ... sawzall ... torch ... plasma ... and if all that fails, I gnaw on it with my teeth!
Shane is offline   Reply With Quote
Old 09-29-2007, 03:50 AM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
I thought about using my jigsaw, but didn't think it would be that effective. I'll give that a shot too. Between the 4.5" grinder, 3" die grinder, 7" metal cutting blade in the Skil, and the jigsaw, I'll find what works best for me.
Thanks guys...
-Chris
Old 09-29-2007, 09:06 AM   #10
jlaird
jlaird's Avatar
sometimes i use a combo of cutoff wheel first, then the sawzall to finish it off.
jlaird is offline   Reply With Quote
Old 09-29-2007, 01:35 PM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
Yeah, forgot about that one- the sawzall is one of my favorite tools!
-Chris
Old 09-29-2007, 06:15 PM   #12
impala_631
:( BYEBYE :(
impala_631's Avatar
i always used my cutting torch follwed by a pass with a grinder to clean the cuts up, but a plasma is your best bet for shure
impala_631 is offline   Reply With Quote
Old 09-30-2007, 12:18 AM   #13
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I'd use a sawzall
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 09-30-2007, 11:33 AM   #14
Scott68-93-97
Scott68-93-97's Avatar
All of the above work fine you got to work with what you have
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
