09-27-2007, 10:16 PM | #1 |
drag shocks
I have a 69 short bed cst with a 431 big block that dyno 684 to the flywheel. Also has a wilsons turbo 400 with transbrake, aluminum drive shaft, new manual disk brake set up ,mosier 33 spline axels with full spool. My question is that i can't find anybody that carries drag shocks for the trailering arm with coil springs suspension. I have lowered the truck 2 1/2 in front and 4in. in the rear with shock relocaters on the rear from early classic. It ran a best of 11.96 at 110 mph. with a 1.76 60ft. It had 16 in centerlines with worn 10 in. hoosiers that were spinning off the line. I have sinced replaced the tires with a 12 in. qtp hoosier which i had to make wheel tubs wider. Haven't taken truck back since i replaced tires. Should hook better with new tires. Also does anybody know what this truck might weigh? There was a similar truck at the track and he said that his weighed 4800lbs.
09-27-2007, 11:27 PM | #2 |
Re: drag shocks
It's been a while since i weighed my truck but it was 3200 before the roll bar and bed cover was added. Maybe 3500 now?
383 s.b. 9.0:1 comp. Turbo 400, 3500 stall. 410 gears in stock rear. Drag shocks? Moroso 90/10s up front, Gabriel gas out back. 1.72 60s.
"Keep your nose to the grindstone it sharpens your boogers" Steven Tyler |
09-28-2007, 12:01 AM | #3 |
Re: drag shocks
I thought a small block short bed weighs right around 4000, maybe even slightly less. So add, what, 200 lbs for the big block...~4200ish
09-30-2007, 07:12 PM | #4 |
Re: drag shocks
I would recommend coil-over shocks and lose the coil springs!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
