#1 | |
bbc cam blues
anyways, before i get the "did you search" question, yes sir i did. but the search engine its not working properly or not at all. it never really does. anyways, my gen v 454 is just asking for a cam, but before i go ahead and purchase one, what are some good cams that i can look at. this is what I'm looking for in cam.
1. your typical "i wanna be streetable but powerful". cliche, but i want that. 2. decent idle, does not have to be perfect, but streetable.. 3. and most of all, dependable. too much to ask maybe, but i have to get my ignorance out of my way before i purchase something that's not gonna work out. can you guys educate me on some cam numbers? like what can be used in the street and what cannot? I'm assuming by the rule of thumb that you might as well replace lifters and springs, but is there anything else i have to replace fr this particular set up? i don't wanna bus something and fin out it will interfere with something else. my current set up is as follows. 750 eddi carb and performer 2.0 manifold. stock everything else, the smogged out cam is keeping me under 200 hp. and i hate that. i can spend up to 350 bucks btw. thanks a lot for your help
Re: bbc cam blues
This is the one I used in my old 402. Made a big change in felt power and economy. http://cranecams.com/?show=browsePar...tType=camshaft
It had a slight lope and from start to 3800rpm it was real strong. I did not need to machine anything to install it on the old heads. The write up on the cam has recommended springs and retainers for after 80 engines.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
Re: bbc cam blues
every major cam manufacturer has a tech line and i've found many to be quite usefull// having all your specs weight ratios tire sizes engine mods tranny type and you expectations of performance will help them give you the ideal cam for your application
Re: bbc cam blues
Me and a couple buddies have had bad luck with Comp Cams. Might be wise to stay away from them, unless you enjoy rebuilding your engine.
![]() Join Date: Feb 2000
Re: bbc cam blues
I have a Crane Energizer cam in my 1989 454 and really like it. It is the Crane Energizer Part No: 103042, Grind Number 266 H10. You definitely want to go with new lifters and springs. My springs needed shimming and after an initial screw up I pulled the heads and had a valve job done on them and let the engine guy get the springs properly shimmed. I am using Comp Cams Magnum roller Rockers and stepped up to better pushrods while I was at it.
This cam is designed with low end torque in mind. Member Billa was kind enough to do a desktop dyno for me a while back (you can see it in the Desktop Dyno sticky in the engine forum) and that program estimated my torque to peak at 433 and my horsepower peaked at 292 - this is with stock peanut port heads. The torque curve stayed above 400 from idle to just about 4000 rpm. I picked the cam with the recommendation of board member Mike C and a call to Crane to see what they recommended. I have a great idle, you can tell the engine is not stock by the sound and I have all the power I need. Crane's tech seemed to know what they were talking about and assisted me nicely given that I'm pretty uneducated engine wise.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 09-28-2007 at 11:14 AM. |
![]() Join Date: Feb 2004
Re: bbc cam blues
all i can say is isky or crower take your pic call em and let them tell you your best option, it all depends on wt of truck, tire size, tranny, stall, induction, exh etc...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Re: bbc cam blues
I was asking the same question about a month ago. I have a friend that is sponsered by comp cams. He told me to give them a call, let them know what I have and what I am looking to do with the engine and they will either reccomend a pre made cam or for a little extra they will grind one especially for the application. My buddy told me to pay the extra and have one ground specifically for the application. It is not as much to have one special made as you would think. My last small block cam cost me about $350 to have made (by comp cams). I know people on this site either hate or love comp cams, but the simple truth is any cam can and will fail if not installed and broke in properly. I personally like comp, and lunati, but that is just my opinion.
A sweet 2000 Deville..... |
Re: bbc cam blues
I agree, but 6500 miles, and 7 wiped lobes within the last 50 is not a break-in problem. And Comp would not stand behind it. The warranty guy at Northern Auto Parts did though. And I got a new cam and lifters by Crane. |
Re: bbc cam blues
comp cams is overated they relly suck, most people get them cause there cheaper, why cause there masproduced, not that the others are not just not in as much volume, isky, crower, lunati all better cams, they produce more power, have more tought put into the design and have better tolarances when machiened, every one ask why our sand box built engines here in west texas run so well and sound like an alchole engine its do to the proper combo and right cam and (cam brand) i took a comp generic 292 cam out of a motor and put a 284 isky mega cam in on a buddys engine the sound and response was evident right away not to mention his s10 picked up a half second and even though the isky was smaller it sounded way more radical than that comp...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS Last edited by Robznob11; 10-01-2007 at 03:12 PM. |
Re: bbc cam blues
Don't waste your time with off the shelf stuff, since custom grinds are just a few bucks more!!!!! Go to this site and search around.
THIS IS WHERE THE BBC GURU'S SPEND THEIR TIME!!!!!!!! http://www.chevelles.com/forums/forumdisplay.php?f=13 a......
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
Junior Member
![]() Join Date: Mar 2005
Re: bbc cam blues
I love the comp cams hyd roller I put in my 402.Talk about dependable.. I'll never break another cam in ..It's more $ but well worth it. No break in problems . I used there cb-270H-R10 270 DUR 566 LIFT 215@.050 I have always used crower in my race motors but wanted to try a hyd roller in this street motor and I'm very happy with it ...And I'm not easy on this motor its been over a year and still running strong..http://s94.photobucket.com/albums/l1...t=MVI_0948.flv
