hey I got a sway bar off a 71 C20 and I was wondering if this is the biggiest one you can get . I think the size is 1 1/16 sound right? trying to get the right size for new bushings from energy susp . also is anyone using the lowered sway bar bracket from early classic?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
CCRider
The stock one is pretty small. If you want a bigger one, get one off a 3/4 ton 73-up truck,it will bolt right on. When I lowered my 71 I mounted the sway bar directly to the frame.with no brakets except the ones that go around the bushing.
------------------ 72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
supposedly the 3/4 ton burbs had even larger ones, but i had an 85 one and it had the 1 1/16" one also, i would look for 1 ton trucks of later years up to 87 and see. I think the largest there would be wouldd be 1 1/4", if evne that much.
1 1/16" will make a hugeeeee difference in the truck's handling alone. good luck ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 *many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham current fleet: -71 C-10 350/CH465/3.07- basketcase, #1 -90 Cavalier 2.2L sky blue, a driver -84 Z28 5.0L/700R4/3.73 daily driver -84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2 -82 purple Trans Am, project #3 *Paint is overrated* © RSS Enterprises 2000 |
Thats the Hillbilly way
72 Mario; Thats the same size i have on my 72 3/4 ton custom camper .
Bill ------------------ 72 3/4ton Custom Camper BB,400 Dynamax Cermax headers , air,ps,pb,leafsprings tilt,3.54 . 82 chevy silverado sb ,ps,pb pw,pd,air 350/350 Flowmaster 40. Torrance Calif. " If I knew I was going to live this long I would have taken better care of myself "
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
My 3/4 ton front bar is 1 1/8, and the swapped-in bar on the ramptruck is the 1 1/4" 1 ton bar. I used greasable polyurethane for the frame bushings, but have to use the factory rubber for the A-arm because the poly can't handle the swivelling and gets spit out, in my experience.
------------------ Just as if I knew what I was doin'
Just as if I knew what I was doin' |
I picked up a 1 1/16" bar off a 75 Chevy at a wrecker for $20 bucks. Totally different handling truck. Best $20 bucks I ever spent.
Hammer On!
![]() Join Date: Jul 2001
So whats the normal for a 1/2 ton sway bar? i tried to get a bushing set from autoparts store and they said there were 4 different ones for our style trucks? Gotta have the right dia. i guess.....
Aaron (68Custom) 1968 C10 Custom Long Wood Bed New Crate 350/TH400, PS, PB *50th Anniversary Pickup*
1968 C20 Inline 6 250 SM465 4 speed 1968 K10 Inline 6 250 SM465 4 speed |
![]() Join Date: Oct 2001
Mario,
I'm using the Chevy 1 1/16 bar with Polygraphite greasable bushings and lowered mounting brackets from Early Classic. Nice parts and powder coated. Fit perfectly but you have to remove the lower rivet in the front spreader crossmember if your truck was not factory sway bar equiped. The lowered brackets keep things up out of harms way while maintaining the proper angle to the contol arm brackets. One more thing. The former GM at Guldstrand Motorsports, The Corvette suspension people, told me to use marine grease on the poly bushings. It won't wash away and will keep them from squeeking. Tom [This message has been edited by basketcase (edited May 14, 2002).]
'69 swb stepside in progress. '59 Corvette lifetime project |
A correct 1/2 ton sway bar for our trucks is 1", the 3/4 ton is 1-1/16th".
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
Thanks i will order the lowered swaybar bracket soon it will end up costing 50 or 60 bucks bye the time it gets here CAnadian FUNDS SUCK the exchange rate sucks !!!!!
![]() Join Date: Nov 2000
I'm getting ready to install a sway bar in my dropped truck too. Should I opt for the $25 at the wrecking yard, or buy one from classic performance for $150 with the urethane bushings and all? And are rear-sway bars actually necessary? Thanks
[This message has been edited by 72step (edited May 14, 2002).] |
![]() Join Date: Mar 2001
If you go the early classic route, you will
get a 1-1/4" bar with energy suspension poly bushings, the bar comes powdercoated as well. I got one of these kits, mainly because it included all I needed. It even came with original GM brackets where for the frame to sway bar mount goes. Overall opinion: great...but expensive. It comes with EVERYTHING...but that comes with a price. I am happy with mine and it improved the handling tremendously, but my truck didnt have a sway bar to begin with. How much of a difference between 1-1/16 and 1-1/4"....guess I will never know! ------------------ 71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73 See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
Thread Wizard Since 2002
Hey, that is why I logged on tonight, I was going to post the question if anyone had a rear sway bar, where they got it, how they mounted it, and if it made a noticeable difference. Also, if you just have like 2 inch lowering springs, do you need to get the sway bar relocator thing from early classics?
--70 C-10 Longbed --71 C-10 Longbed --72 K-20 Longbed --74 C-10 Shortbed --86 Toyota Tercel (His Driver) ![]() --05 Chevy Trailblazer (Her Driver) |
#15 |
I got a 1-1/4 inch sway bar from an '84 dually. There were a couple other duallies in that junkyard with that same size swaybar, so you might want to keep an eye open for a dually if you want that size.
