Old 10-03-2007, 04:33 PM   #1
GBWatts
GBWatts's Avatar
Back-Up Lights
I'm pulling my hair out trying to figure out my back-up lights, they just don't work period, I am not getting any power back to the lights, fuse is ok, lights are brand new and I bench checked them before I installed. Where should I start looking? BTW, I have a 68 stepside LWB,
GBWatts
68 C10 Stepside LWB
Howell, MI
GBWatts is offline   Reply With Quote
Old 10-03-2007, 04:44 PM   #2
northerngmc
northerngmc's Avatar
Re: Back-Up Lights
Is the reverse switch hooked up? If the truck is an automatice or 3 speed manual the switch should be on the column. For a 4 speed I believe it is on the transmission.
You can take the wires off the switch and with a test light you should have power to one side of the switch. If you do, then use a jumper wire and put power across and eliminate the switch, and if they work now you probably have a bad switch.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 10-03-2007, 05:06 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Back-Up Lights
The lights also need to be grounded to the bed. There should be a ground strap from the bed to the frame. If your truck has been repainted, there may no longer be a metal to metal contact.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-03-2007, 07:28 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Back-Up Lights
Mine did not work when I got the truck.I used a nutdriver(5/16 I think?) and adjusted the backup light switch.Took all of about 5 min once I figured out the problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-03-2007, 11:30 PM   #5
wibilly
wibilly's Avatar
Re: Back-Up Lights
i just fixed mine yesterday by ajusting the neutral safty switch
common sense isn't so common anymore
wibilly is offline   Reply With Quote
