09-29-2007, 07:41 PM | #1 |
BAD BOW-Silverado XST
Zz4 Is Running!!!
I just about jumped out of the seat. The ZZ4 cranked up on the 2nd crank!!
Sitting in the seat feels like sitting in drag car! It shakes, rumbles, rough idle and smokey!!! The plugs burned up the oil used to turn the motor over. The ZZ4 cranks up quickly and scrippy!! Video coming soon!! I need someone to hold the camera!! THANKS TO EVERYONE WHO HAS HELPED ME THROUGH THIS PROJECT!! You can't believe the smile on my face to hear the ZZ4 run. I had neighbors come out and look!! A little tidy work to check for leaks, loose bolts, tie wrap some wiring and electric fan check are needed. I can't wait to put my foot in it!! |
09-29-2007, 09:06 PM | #2 |
Slugish
Re: Zz4 Is Running!!!
Congrats on your project . nOT FAMILIAR WITH ZZ4 . iS THAT A CRATE ENGINE .WOULD BE INTERESTED ON ENGINE SPECS ESPECIALL Y DURATION OF CAM .
09-30-2007, 08:23 AM | #3 |
Block Part Number: 10105123
Block Type: Cast iron with 4-bolt main caps Bore x stroke (in): 4.00 x 3.48 Camshaft duration (@.050 in): 208 degree intake / 221 degree exhaust Camshaft lift (in): .474 intake / .510 exhaust Camshaft Part Number: 10185071 Camshaft type: Steel hydraulic roller Compression ratio: 10:1 Connecting Rod Part Number: 10108688 Connecting rods Type: Powdered metal steel Crankshaft Part Number: 12556307 Crankshaft Type: Forged steel Cylinder head Part Number: 12556463 (angle plugs, Vette head) Cylinder head Type: Aluminum; 58cc chambers Displacement (cu in): 350 Engine Name: ZZ4 350: Engine type: Chevy small-block V-8 Ignition timing: 10 degree BTDC @ 800 rpm 32 degree total @ 4000 rpm with vacuum advance disconnected Maximum rpm: 5800 NOTE: Distributor with melonized steel gear MUST be used with long blocks partial engines with steel camshafts, or engine damage will occur. Piston part Number: 10159436 Pistons Type: High-silicon aluminum with offset pins Recommended fuel: 92 octane Rocker arm ratio: 1.5:1 Rocker arms Part Number: 10089648 Rocker arms Type: Stamped steel Valve size (in): 1.94 intake / 1.50 exhaust |
09-30-2007, 02:46 PM | #4 |
Dark Heart Motorsports
hella grats brotha...glad to hear you got her goin again.
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
10-01-2007, 09:29 PM | #5 |
Master Blaster
congrats!!! you will be even happier when she is rollin........Sorry I didn't get back with ya about your questions, I have been really busy out here now that the weather has cooled down a bit. Let me know if you have any others questions I might be able to help with....jesse
10-01-2007, 11:27 PM | #6 |
Insert Witty Text Here
Congrats, G.
Slonaker |
10-01-2007, 11:41 PM | #7 |
I need to work on cleaning up a few items. The next step is fix the alternator. Right now the ZZ4 will is running off battery power. The serpentine belt system has a CS130. I plan to use an LED light to tell me when it's charging.
10-02-2007, 09:07 AM | #8 |
STILL PLAYS WITH TRUX
So does this mean your not MR. 305 Any more
Congrats G! Your gonna like it my buddy and i put one in a '55 Belair and that thing was a kick in the ass when ya opened it up |
10-02-2007, 01:12 PM | #9 |
Sweet! Congrats, man. Can't wait to see the video. If I wasn't so far awy I would come hold the camera.
10-02-2007, 03:39 PM | #10 |
i got a cs130 off my serp setup in for sale section...
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
10-02-2007, 07:09 PM | #11 |
[QUOTE=87 STEPPER;2384769]So does this mean your not MR. 305 Any more [QUOTE]
Officially yes. However until someone else can get a 305 into the 16's-15's I can honorarly hold the title to the badest stock 305. The little 305 could spank a stock 350 like spanking the neighbors milk man's kid.... Now much can I get out of the ZZ4? I don't know but you know I'm going to try. I have a 750 carb ready to bolt on. The 650 is probably enough, but the RPM Air gap intake should handle it. I know the tires won't. |
10-03-2007, 09:49 AM | #12 |
Awesome G! Good to hear. If you need someone to hold the camera, you let me know. I would love to hear it in person.
10-03-2007, 09:22 PM | #13 |
Spear and magic helmet!
I have no idea what "scrippy" means, but I know you've been working on getting this in and going for awhile now. Congratulations!
On a side note, your geocities site was one of the first few I found when I got my truck like 6 years ago. I've read it front to back a few times, pausing for a day to let you come back down within the bandwidth limit. I'm glad you put up that site, dude. It's been very motivational over the years.
-- Will |
10-03-2007, 10:01 PM | #14 |
cool............gonna drop one myself someday.
" Never look up a dead dogs butt." |
10-04-2007, 09:07 AM | #15 |
Thanks fellas. I want to host an Austin gathering once it's road worthy again. The ZZ4 starts easier than my FI Jimmy. The ZZ4 starts with the slightest starter bump. I'm still working on the videos. I need to fix the oil pressure and tach guages. The digital gauges are not working. I need them to work before the ZZ4 can run for more than a few minutes.
