09-28-2007, 08:26 PM | #1 |
Air Compressor Timer
I forgot to turn off the circuit breaker to my air compressor last night. Well, during the night it turned on, and at some point both connecting rods broke. Since it couldn't build pressure, it ran for who knows how long until I heard it running this morning.
Is there a method or system available to prevent an air compressor running uncontrolled for long periods? I thought of using a timer that could be set to run for, say, 30 minutes every time the compressor starts and resets when the compressor turns off. I think that would be long enough since I don't believe I would ever need to operate the compressor any longer, but if it were unattended, short enough to prevent an uncontrolled run time. I've searched online, but haven't found anything that has a delay longer than 17 minutes. Any thoughts? Thanks! Larry |
09-28-2007, 08:57 PM | #2 |
Overdrive club
Re: Air Compressor Timer
Ouch,most compressors have a pressure switch that turns em off.
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
10-04-2007, 02:19 AM | #3 |
Wonder if an attic fan timer would work? My attic fan, ~1950 vintage, has a metal control box on the wall that lets you run it for up to an hour or two before it turns itself off automatically. It has an over-ride lever on the bottom so you can turn it on forever if you want to. I don't know what the horsepower rating is, but that type of timer might be what you need. www.mcmaster.com has a good selection of them. Search for timer switch.
10-04-2007, 04:42 AM | #4 |
Earl 68 2500 4x4 GMC Burb |
10-04-2007, 07:28 AM | #5 |
Happy to be here
Get a sprinkler timer. It doesn't care what it turns off and on.
10-04-2007, 08:31 AM | #6 | |
That said, instead of some timer, I'd put a working low and high pressure on and off switch on it - like the one from Northern Tool pictured above. Me? I manually turn mine off. Yeah, I've forgotten before, but the upper end pressure cut-off worked like it should. If the air compressor pump chucked its rods, are you just going to replace that or?
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
10-04-2007, 09:02 AM | #7 | |
More Cowbell....
Why not wire an outlet to work from the light switch. That way, when you are in the shop with the light on, you have air. When you leave, the lights are off....and so is the compressor. I wired an outlet like that in my new house, so when I leave the laundry, the outlet used for ironing goes dead with the light switch. No chance of leaving the iron HOT.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 10-04-2007 at 09:02 AM. |
10-04-2007, 09:09 AM | #8 | |
10-04-2007, 09:30 AM | #9 | ||
10-04-2007, 09:31 AM | #10 | |
