Old 12-30-2002, 04:06 AM   #1
tywhitty
Question pulled oil drain plug,drained 5 gallons of fuel!?!?
my truck has been sitting for a while (4 months) and I decided to get it running... well I checked the oil and it seemed awfully high and lean... I pulled the oil drain plug and out comes enough oil\gas to fill a 5 gallon bucket! What the hell is going on here? Cracked intake manifold? Carb? Neighborhood kids playing pranks? Any suggestions? Thanks 67 C-10 3/4 327/TH400
tywhitty is offline   Reply With Quote
Old 12-30-2002, 04:11 AM   #2
Hooter
My other Love
Hooter's Avatar
Well i would have to say your motor was reeeaally flooded. your oil turned real bad or someone is trying to make a monkey out of you. Welcome to the board from not too far North of you! Are you sure its oil and gas or could it be water?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-30-2002, 04:13 AM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
My bet it a bad fuel pump.If the diaphram gets a hole in it the truck may still run but at the same time it will dump fuel into the block(which ends up in your pan).DON'T run your eng. untill you change the oil.Let's hope your bearing damage is minimal.
You can check the fuel pump by applying vacume to the "in" side of the pump(where the fuel line from the tank is connected to the pump)If it won't hold vacume the diaphram has a hole in it.
Good luck.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-30-2002, 04:17 AM   #4
Hooter
My other Love
Hooter's Avatar
well with all that gas in there, I would be pretty sure the motor is clean inside
pictures of my life
Old 12-30-2002, 06:15 AM   #5
jku72
Fuel pump. Been there, done that.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 12-30-2002, 10:27 AM   #6
67/72junkie
fuel
If float sticks in the down position while parked it will do this when fuel pressure is applied.Turning to start. Also could be fuel pump as others said.
67/72junkie is offline   Reply With Quote
Old 12-30-2002, 11:06 AM   #7
wnc mountain
More hobbies than money!
wnc mountain's Avatar
I'll vote for fuel pump! don't think you could get that much gas in the oil from the float sticking, though i could be wrong.
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
Old 12-30-2002, 01:52 PM   #8
cheyenne10
cheyenne10's Avatar
electric fuel pump
I'm not real familiar with electric fuel pumps but have seen them where the pump still runs when key in on position and truck not running. Wouldn't this situation dump loads of fuel into motor with truck equiped with el. fuel pump and someone listening to radio?
Does anyone run an electric fuel pump and how does theirs work? Maybe a better option if used right avoiding diaphram hole situations.
Not trying to change subject of this post maybe we should start another.
Bob
cheyenne10 is offline   Reply With Quote
Old 12-30-2002, 02:08 PM   #9
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
No, the fuel pump only runs for 2 seconds without distributor input. On fuel injected models anyway. Didn't think about the not fuel injected ones. Dang. Sounds like a mechanical fuel pump problem though. I'd check the diaphragm. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-30-2002, 02:37 PM   #10
racedvl
racedvl's Avatar
FUEL PUMP!!!!!!!!!!!!!!!!!
racedvl is offline   Reply With Quote
Old 12-30-2002, 02:47 PM   #11
COBALT
COBALT's Avatar
I would agree with the fuel pump. You can at least pull it off and inspect the diaphram and gasket!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 12-30-2002, 04:23 PM   #12
Iron-Butt
454 club
Iron-Butt's Avatar
fuel pump
We had the same problem on the chevelle. fised the pump and changed the oil. it works just fine.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 12-30-2002, 08:16 PM   #13
Hooter
My other Love
Hooter's Avatar
Oh i put a new 300 6 into my 1981 f150. the motor came out of a fuel injected truck but i put a carb back on it. There were no provisons for a mechanical fuel pump so I put and electric one on. If I don't start the truck right away it will flood like a s.o.b
pictures of my life
Old 12-30-2002, 09:57 PM   #14
lofly'a
lofly'a's Avatar
hey hooter, if it floods that quick you either have too much pump pressure or the needle valve and seat is not holding in the carb. you only need about 7 to 12 psi for the carb, and you can install a fuel regulator inline to solve that problem. if the needle and seat are'nt holding you're sucking down way too much fuel.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 12-31-2002, 12:12 AM   #15
RShaips
FUEL PUMP! been there done that 3 Times !
RShaips is offline   Reply With Quote
Old 12-31-2002, 12:30 PM   #16
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I have no idea what the problem is, but welcome to the board from Bothell.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-31-2002, 10:59 PM   #17
robby
Semper Fidelis
robby's Avatar
that happened to my dad he trashed his engine unfortunately
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
