Re: '70 grill or '71
I like the 69/70 grill better.
How about doing what I did. I wanted driving lights. (They came out with the re-pop, driving light integrated bumpers after I started acquiring parts). I put a 71/72 bumper on my 70 look-alike truck. You'll need the 71/72, 4x4 front bumper brackets. I THINK the 71/72 front brackets will work with the older style (no turn signals) bumpers. If you find a set of those you can change your mind later.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
![]() Join Date: Feb 2001
70 is swaaaaweeeet!!...
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 10-08-2007 at 08:06 AM. |
I'd say go w/ the 70 !
"I feel the need for speed!"... as soon as I am done with my nap. |
I put a toggle switch in the cab. When the lights are on, the switch has a little LED that lets you know the circuit is getting power.
The switch gets power from a "on when key on" spot in the factory fuse panel. That wire goes to a relay under the hood. The relay then supplies 12 Volts directly from the battery to the lights. I mounted the driving lights in a set of 71/72 blinker assemblies that had light sockets that were corroded beyond usefullness for what they were intended. I removed the bad sockets and mounted the Wal*Mart driving lights to the lensless, bulb socketless stock assemblies. If I ever find a driving light that fills the hole in the bumper better I'll be swapping them in.
