#1 | |
Parts and more parts
Re: Carb choice for 350
[QUOTE=slugish;2393011]
A couple of questions that are kind of outside the discussion---1) What cam design are you running? 2) Does your truck pull at a stoplight, while you are sitting waiting for it to change? REASON for questions---If you put in a cam that is rather healthy, then your truck is probably working itself against the torque convertor and tranny (I am guessing you have an automatic--I may be wrong). This bad idle and the torque convertor lends to loading up your engine with raw gas (due to having to set the idle high on the carb to overcome the bad idle conditions). This is primarily due to the idle adjustment is NO LONGER in the idle circuit on the carb ---it is now in the transition area. If so, then a change to your torque convertor's STALL is necessary to get your idle screws back where they belong (JUST A GUESS). I had to take my stroker motor's tranny to a 2400 stall to get a better run and idle response. The change was tremendous. |
#2 | |
Slugish
![]() Join Date: Jan 2005
[QUOTE=piecesparts;2393440]
Cam is pretty mild 048 lift - 224/ 230 duration the guy that built engine said to check for leaking while running (havent done that yet ) what do you do , just look inside carb while running . Was talking today to another friend who builds race cars . He said double pumpers are for racing , not really good street carbs & probably dont have enough lift for the amt. of gas a double punper puts in . Ived been advised by him & others to get a quadrajet or eldobrock for the street & occasionaly the strip 750 cfm quadrajet or eldebrock with a vacuum secondary & electric choke also I put truck in neutral most of the time at stoplights Actually runs well in most all rpm ranges. its a 408 cube sbc with reworked stock heads. What would be your choice of carbs/ thanks for your help by the way |
#3 | |
[QUOTE=slugish;2396155]
Before I purchased my carbs, I talked to the reps at Holley and the reps at Edelbrock (I do like going on the Hot Rod Power Tours--just for that reason). Of course, they all push their own items, but they also quote a lot of info and most say the same thing. For a truck being driven on the street, you want to keep the airflow velocity up, so that it will not lag behind the motor. That means running a slightly smaller CFM carb. The heavier weighted vehicle will respond better to that thought process. (Example run a 625 or 650 CFM carb rather than a 750 CFM and the response will be better) A lighter weight car, such as a Camaro will work better with the 750 CFM carb. The Holley people support a vacuum secondary actuated carb is better, they say the feathering of the secondaries is smoother. I have found that the Edelbrocks that I have run work just as well without the vacuum actuated diaphragm design. (I have adjusted my springs, needles and jets to what I like) Did you know that the Edelbrock AFB design carb and the Carter AFB design carb is the EXACT SAME carb. (both carbs are made by Magnetti-Marelli) The parts are interchangeable---even if the parts distributors say that they aren't. I have a Carter in my basement that is full of Edelbrock parts (Edelbrock is cheaper than Carter on parts) You still need to make sure that you are getting your carb adjusted to where the idle is in the idle circuit part (butterfly relationship to the venturi)and not in the transition area---gas smell and bad mileage is normal there. Where do you have your idle mixture screws set at? I set mine using a vacuum gauge instead of by ear, however both methods work . I am also going to ask, where do you have your intial timing set at? Maybe it is set to low. If you think that your carb is leaking gas, try closing down on the idle mixture screws and see if it runs with them closed off. There is a possibility that it might with the gas leaking into the intake. |
#4 | |
Slugish
[QUOTE=piecesparts;2397436]
