Old 10-07-2007, 12:37 PM   #1
chvtrkman
chvtrkman's Avatar
Question Ignition timing
Sorry if this topic has been discussed to death. I did a search but turned up nothing specific to my problem. Here goes:
My 292 has no power above 1500 rpm. I went to check timing yesterday, I put the timing light on it....can't find a mark lining up anywhere on the timing tab on engine block.My question is, would my truck even run if the distributor were to have gotten off a tooth? I didn't pull the dizzy, but a friend who worked on it for me in my absence may have.Any clues?
BTW: the truck is a tiny bit hard to start when cold, but once it idles a minute or two it starts easily, idles ok, and revs ok. just when I drive it, it cuts out after 1500 rpm, and has little to no power to climb a grade. I haven't checked for a vacuum leak yet as I want to make sure timing is correct first.Any help is appreciated.
69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt"
78 C-10 305 TH350 new (old) daily driver
02 Suburban Z71 a.k.a. the family truckster
99 Silverado 1500 Z71
chvtrkman is offline   Reply With Quote
Old 10-07-2007, 04:14 PM   #2
chvtrkman
chvtrkman's Avatar
Re: Ignition timing
Ok,so I reset the timing to 8 degrees BTDC. Checked for a vacuum leak....everything's good there. Tried making carb adjustments 5 times.
The best I could get before it starts to cut out is 2000 rpm. Once again, I'm baffled.
Old 10-07-2007, 07:37 PM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Ignition timing
Clogged fuel filter? Severely clogged air-filter? failing fuel pump? Points or electronic distrib? If points, dwell off?,points all burnt or oily? Carb clogged with gunk? Timing weights stuck and not advancing the timing as RPMs increase?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 10-07-2007, 08:02 PM   #4
chvtrkman
chvtrkman's Avatar
Re: Ignition timing
WorkinLonghorn,
Thanks for the reply. Sometimes I neglect to give info that I don't think is pertinent to the problem. For example, the carb is new(installed in May of this year), as was brand new air cleaner, fuel filter, etc. New points,plugs,condenser as well.Pretty much all that stuff is new as the truck sat for 5 yrs. out in the woods.
I went out to tinker after dinner, I reset the timing back to original setting, only this time didn't use timing light, just did it by listening as I turned the distributor. That, in combonation with the leaner carb adjustment made a big difference, but it's still not 100%.At least I can drive up a mild grade now. I still haven't checked the fuel filter ( even though it's new) for debris clogging it up. I think I've narrowed it down to either that, or a bad vacuum advance. Tomorrow I will see if our local auto parts store will have one. If not I can order one from a supplier on the "net".Thanks again.
Old 10-07-2007, 08:20 PM   #5
68 Stepside
huh?
68 Stepside's Avatar
Re: Ignition timing
My 66 3/4 ton had a leaky vacuum advance, it was a total dog until I fixed that. Fortunately it had 4.57 gears , so I really didn't have a lot of problems with grades anyway...
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-07-2007, 08:40 PM   #6
WorkinLonghorn
Re: Ignition timing
The vac advance only affects part throttle operation (if installed correctly).So if you floor it going up a hill and the engine misses or runs real weak,it's not the vac advance (but it could be the centrifical adv.).Apply a partial vacuum with your mouth to the vac-line and you should see the points rotate counter-clock-wise.
If you have an old gas tank,it could very easily clog the filter in no time at all.I had to mount a huge filter on mine about the size of a lawnmower muffler to get some serious use from my old '69 between fuel filter changes!
Old 10-07-2007, 08:58 PM   #7
DavesRide
DavesRide's Avatar
Re: Ignition timing
Here is a good trick to find if fuel is an issue. Take one of those small propane touch bottles and take off the tip. Put a piece of hose on it long enough to reach carb from drivers seat. drive vehicle and when it malfunctions turn on propane and if it runs better it has a fuel delivery issue. I did this to an old quadrajet and figured out my metering rods were not raising up to deliver fuel once the secondary flaps opened. Just a thought. Dave
DavesRide is offline   Reply With Quote
Old 10-07-2007, 09:09 PM   #8
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Ignition timing
Good tip, just be careful. The tube runs where on the carb? The top?
The nice thing about that idea is if it's not a fuel issue, you can end your problems with the torch in you hand.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-07-2007, 09:49 PM   #9
DavesRide
DavesRide's Avatar
Re: Ignition timing
Yes, very true. Be safe. I ran mine into the top opening of carb and held it in place so it did not go anywhere else. If the truck in question is missing under load then do look into ignition system. If it feels like it just holding back still on 8 cylinders then check into fuel. Yes, do not set it on fire.
Old 10-08-2007, 10:05 AM   #10
Alex Hayley
Re: Ignition timing
Did you check for a stuck mechanical advance? I just worked through that issue a couple of weeks ago.
Alex Hayley is offline   Reply With Quote
Old 10-08-2007, 10:35 AM   #11
WorkinLonghorn
Re: Ignition timing
I already mentioned that twice.
Here;
and here;
