Old 10-07-2007, 07:41 PM   #1
PETEM1957
Junior Member
Question Clutch bracket - Frame side
I need to know if the frame mounted bracket for the clutch linkages are all the same for 6 cyl and V-8 applications? I'm trying to sort it out for a '70' K20 with a SBC and Granny 4 speed. I have '67 C-10 roller which is original I6 and 3 on the tree and the bracket is riveted in and has a bit of a dogleg in it but it's different than the existing one on the K-20 which is stamped steel but does not have the dogleg it it.
Any pics of stock linkage would be a great help.
I think PO may have used the wrong style (year) things just do not line up right and the clutch rod from the pedal to the Z-bar was welded up. i got all the new pieces i could find from different board vendors but was not able to find bracket as a repop item.
Any help and guidance would be greatly appreciated!!!!!!
PETEM1957 is offline   Reply With Quote
Old 10-07-2007, 07:47 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Re: Clutch bracket - Frame side
They are not the same. I *think* you can turn the bracket around 180 degrees to use on a V8, if it was originally an inline, or vice versa. I may be crazy, but that's what I thought I'd heard in the past. I'm sure someone will chime in and either confirm or deny this.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-08-2007, 09:33 AM   #3
PETEM1957
Junior Member
Ttt
Old 10-08-2007, 11:37 AM   #4
Mt Man Chad
Mt Man Chad's Avatar
I'm pretty sure after looking at a few of mine they are the same I6 and a V8. there is a difference in the frame mount from a 67~68 truck and 69~72 because the frame wasn't recess in that area in the first two years.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 10-09-2007, 01:25 PM   #5
PETEM1957
Junior Member
Ttt
Old 10-09-2007, 01:29 PM   #6
1969K10
1969K10's Avatar
Not an expert, but when I swapped my old I6 for a V8, I reused the clutch bracket that was existing. The clutch rod was at a slight angle, but worked flawlessly and w/o binding. For what it's worth, that was on a '72.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 10-09-2007, 01:55 PM   #7
PETEM1957
Junior Member
Ok, so i guess they are the same - I'll throw a WTB thread in the parts forum and see what someone might have. Thank's Guys!
