Old 10-09-2007, 03:55 PM   #1
Pyrotechnic
Pyrotechnic's Avatar
Turbo 350 vs. Turbo 400 crossmember
Are the cross members different? or is it just a matter of the mounting holes for the cross member being further back on the frame ?
Pyrotechnic is offline   Reply With Quote
Old 10-09-2007, 05:30 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: Turbo 350 vs. Turbo 400 crossmember
Crossmembers are the same. It will need to be moved to mount up with the trans mount. You may also need to drill a hole or two. I had three line up on mine when I went to a th400 from a th350.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 10-09-2007, 05:35 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Same exact crossmember, different locatin. The 400 is about 5-11/16" longer to the mount.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-09-2007, 05:52 PM   #4
Pyrotechnic
Thanks guys. The RPO sheet on my truck indicated that the truck originally came with a Turbo 400 but when I bought it, it had a Turbo 350. I was looking to install a 700R4 or 2004R which uses basically the same cross member location and if the holes are already there then thats one less thing I have to worry about. I'll have to get under the truck sometime and see what I got.
