Old 10-10-2007, 12:58 AM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
3" Blocks
Anyone running 'em?
I'm worried about scrubbing the lower shock mounts out back. I'm running a 20" wheel with a 30" tire. An extra inch would be nice though...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-10-2007, 11:46 AM   #2
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: 3" Blocks
I thought about running them too, but if ya get a flat it's bad news.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-10-2007, 06:48 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
Re: 3" Blocks
When you notch it you will lose the upper shock mount x-member and therefore relocate your shocks as I did (I'm assuming). So you'll gain some scrub-line margin there.
With the 20's and the shock relo you will be above the scrub. Here's how I know: I'm runnin 3" blocks (2.75+0.25 super-track-bar bracket). With my current 17" wheel/tire combo with rim is 2.75" from the ground and the lowest hanging suspension part (lower bag bolt) is also 2.75" off the ground. Very marginal, I know, but the 22's will remedy that
So, with your 20's you'll have 1.5" more clearance than I do. Here are some pics:
Frizzle Fry is offline   Reply With Quote
Old 10-10-2007, 07:46 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Re: 3" Blocks
Just curious- have you guys done any adjusting/shimming of the driveshaft angle?. At what amount of drop is this a concern?. I have 4" drop springs now and plan to add 1-2" blocks in the future. Don't mean to hi-jack Gringoloco
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-11-2007, 12:04 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 3" Blocks
Originally Posted by Frizzle Fry View Post
Here are some pics:
Thanks Frizzle. You da man! That's exactly what I was lookin' for. What did you make your blocks out of and where'd you source it?
No worries on the thread jack- we're all here for the same thing. I set my pinion angle by using new perches from ECE, but that was before- I am going a LOT lower this time around. I will get some angled spacers if necessary once I set my ride height. They are available through many sources, but cheapest through circle track racing shops- they use the trailing arm set-up on the roundy-round cars.
-Chris
Old 10-11-2007, 12:26 AM   #6
Frizzle Fry
Re: 3" Blocks
I made those and the U-bolts back high school metal shop In case you're wondering, that was sometime between 91 and 95 The blocks are solid aluminum. They've been it three different trucks
