Old 10-12-2007, 07:02 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
key question
I looked in the ownes manual, and it says nothing about this.
Does the tail gate use the ignition key? I can't even get my key in the lock. I probably need a new key set anyways, do they make anything for the tail gate?
Old 10-12-2007, 07:21 PM   #2
zeusflash
zeusflash's Avatar
Re: key question
On my wifes 72 Suburban one did it all,doors,ignition and liftgate(my Blazer was this way too until I had to rekey). I too had a problem with the liftgate lock. When I took the liftgate handle to the locksmith for rekey he found an original key end broken off in the lock! We used this to make keys that actually work in all of the locks.
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
Old 10-12-2007, 07:22 PM   #3
shaneschevys
Its always something!
shaneschevys's Avatar
Re: key question
I dont think that they make anything lock wise for the doors or the gate. The tail gate button is some what similar to the push button on the 60-66 trucks door handle. It could possibly work.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 10-12-2007, 08:31 PM   #4
centsless
sufficiently talented fool
centsless's Avatar
Re: key question
Andy, I just went out and one key works all of them on mine.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 10-12-2007, 08:46 PM   #5
CG
BlahBlahBlah
Re: key question
Thats the only key I got with the burb Andy. Centsless is correct on how they work. Course why wouldn't he be, he just tried it out for you...
Old 10-14-2007, 09:44 AM   #6
MrGoodpliers
MrGoodpliers's Avatar
Re: key question
I had some trouble with mine, too. I took it apart and cleaned it up (not as scary as it sounds) and now it works great. When I got it apart, it wasn't difficult to see what the problem was. I can't remember if i used wd-40 or graphite inside. probably wd-40.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 10-14-2007, 08:03 PM   #7
Longhorn Man
Re: key question
i tried squirting PB Blaster in it, can't take it apart though since I can't turn the key.
Old 10-16-2007, 10:19 AM   #8
MrGoodpliers
Re: key question
You should be able to get it out from the inside, then pry the button cover off of the cast housing. Then just clean everything and adjust all of the little springs. Good luck.
