10-08-2007, 06:59 AM | #26 | |
Sierra Grande Club
Re: Roller rocker hitting stud shoulder….
the concern here is it's not quite the same as the ones I'm using. so he's my idea. I'll get mine and measure the difference. I can turn them on the lathe to make it a little shorter, or tack on some metal on the bottom, then turn them down to size. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
10-08-2007, 10:55 PM | #27 |
"Trucks with Class"
I just get another hyd lifter...open it up...pull out the guts and replace them with a solid plug so everything stays the same.
10-09-2007, 07:08 AM | #28 | |
Sierra Grande Club
I talked to the machine shop about milling my heads. $100 I need to get the guide plates and studs. he said the plates that raise up help to stabilize the rocker stem better? Any ideas on this? s/t
10-09-2007, 09:10 AM | #29 |
Next project: 1970 K10
He's probably talking about these:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 10-09-2007 at 09:10 AM. |
10-09-2007, 09:58 AM | #30 |
I'm just reading through this and had a couple of thoughts.
DEFINITELY agree that if you're running non-self-aligned rockers and no guideplates you're toast. You must have one or the other - period. Note that if you run guideplates, you must run hardened pushrods. Other than machining the boss, the only other option I can think of is longer pushrods + lash caps to keep the geometry right. I agree with your shop - the right approach is to go with the guide plates and the shoulder studs...and hardened pushrods. |
10-13-2007, 09:55 AM | #31 |
Sierra Grande Club
Update:
I got a stud extractor & pulled off my studs. My concern was the holes weren’t going to drilled/taped deep enough. Causing concern with gong in threaded holes to drill and re-tap without destroying the existing threads. The good news is all the holes are taped completely. So all that is needed it to machine the bosses! I looked at ARP studs and they show a taller stud for use with roller rockers. I think they recommend them because people use stud girdles? Do you think the standard length will work? The standard ARP is a bit longer than what I removed, and I didn’t see where the studs were too short (plenty of thread for the locks). I’ll be using Summit brand raised guide plates (mainly because they are out of stock with other brands) What do you think of this combination? s/t
10-13-2007, 11:25 AM | #32 |
Sounds good. The standard length should work. The longer studs are for a stud girdle. I've used the summit brand on more than a few things and never had any problems.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
10-13-2007, 12:04 PM | #33 |
Sierra Grande Club
That's what I thought. Thanks for the reply.
s/t
