10-14-2007, 06:49 PM | #1 |
Brake Lights
When I turn on the Hazard lights, the front lights up but the back dont and do not blank and no lights in the back. I do not have brake lights I change the switch and I do have one power wire and one ground wire on the switch. I do have power going to the power wire but when I check all wiring and fuses what could be the problem can someone give me the answer what should I check for
10-14-2007, 07:03 PM | #2 |
The One And Only !!!
Re: Brake Lights
May sound stupid but did you check the bulbs ?
There is also a ground wire at the back of the truck from the tail light harness that could be broken/rusted.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
10-14-2007, 09:54 PM | #3 |
Robert Olson Transport
Re: Brake Lights
check the grounds and the connector from the bed to the wiring harness
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
