![]() Join Date: May 2005
shop floor coatings
Has anyone had any good/bad experiences with any types of floor coatings. one stage, two stage any thoughts out there? Will be sealing a floor shortly and need all the help I can muster. This will be a high traffic area and I will need something that will stand up to it...............................TIA..Joe
![]() Join Date: Mar 2003
Re: shop floor coatings
I'll be using the same stuff at home as we use at the shop--a 2 part epoxy. Holds up real good at the shop. Don't have the brand name at the moment
SWB 4X4 CLUB
I am also curious as to what works the best but still is afordable.
Jason |
![]() Join Date: Sep 2005
you would more then likely get a better response in the general discussion section i have notified the mods so that it can get move and i hop you find your answer
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
67-72 Addict!
I'm happy with my Rustoleum Epoxy Shield
Here's before and after
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Rolled on Paint Club
![]() Join Date: Jan 2006
I agree with the Rustoleum product it is a good product for the price. Plan on 2 coats for the best coverage. I have done 2 garage floors with this and they turned out great. Too bad neither was mine
Other good but pricey products can be found here: www.garonproducts.com Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
![]() Join Date: Jun 2003
I used Sherwin-Williams concrete paint after etching the slab. My choice would have been the expoxy, if I could have afforded it. My slab is 30x60, did not leave much for the extras. The concrete floor paint has held up well, but can not handle fuel spills, and tire marks easily.
Thanks all for the replys.Looks like Rustoleum will be used.......Joe
Robert Olson Transport
![]() Join Date: Oct 2002
ive used the rustoleum too and had no problems it holds up well
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Tot Roddin'
I've read through a few other posts on this web, as well as the garage journal form, and the majority of the votes go for the epoxy. That is what I plan on using in our garage when the time comes.
Keep us posted, would love to see the end result.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 10-13-2007 at 10:33 PM. |
25 years in the concrete business and this is the best stuff I've found for garage floors.
http://www.ashfordformula.com/index.html This stuff, or different brand names, is what you see on the floors of the big boxes, like Home Depot or Sam's club. It becomes part of the concrete so there is nothing to peel up and flake off. No dust, no fluid penetration, I've spilled everything from used oil to brake fluid on mine and it just wipes up, and no stain.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#13 | |
1st if you plan on sealing or painting the floor ? my garage gets damp looking after heavy rains , also the last garage I built I told the concrete contractor I wanted to coat the floor and he said "you should have told me that 1st and we would have laid down plastic.On my current shop project my tractor guy came up with a good idea (IMO) he said "add layers of crushed rock as a moisture drain under the slab 1st and you wont need to add a layer of plastic" what would you suggest ? thanks!
"I feel the need for speed!"... as soon as I am done with my nap. |
| Bookmarks |
