10-14-2007, 08:18 PM | #1 |
can it be done?
I have a 250 straight six in my truck. I was wondering if I put in a V8 like a 350cci could I still use my three on the tree? If not, what motor can I use. I would like to put a V8 in my truck. But I really want to keep the three on the tree. Can it be done?
10-14-2007, 08:28 PM | #2 |
BlahBlahBlah
Re: can it be done?
Welcome to the board. Maybe one of the mods will move this thread to an area where you can get more help with your question.
If you're going to use the same trans I don't see why it would effect using your three on the tree. It may require a different clutch pivot. Dont worry you will get this answered pretty quickly on the board. A lot of smart helpful folks here. Last edited by CG; 10-14-2007 at 08:29 PM. |
10-14-2007, 08:31 PM | #3 |
Why does it taste purple?
Re: can it be done?
I have a 350 with a 3 on the tree in my 66 for now. Soon to be replaced with a rebuilt th350
10-14-2007, 09:51 PM | #4 | |
FarmBoy.
Re: can it be done?
bluntly - yes. the 250 and that series of straight six's used the same bell housing as the small blocks. so your, 350 will bolt up to the trans.
i'm not sure of the technicalities of clutch pivot,e tc. but it does bolt to it. my GMC has a 307 with a three on the the tree. and since 307's and 350's and basically the same...yeah. someone else will chime up with more tech info, i'm sure. -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
10-14-2007, 09:55 PM | #5 |
Chevy nut
Re: can it be done?
I have done the 250 to 350 swap. The pivot does need to be changed.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
10-14-2007, 10:11 PM | #6 |
Re: can it be done?
There are different shift rods for V8 and six shooter trucks. But if you used the sixes eingine stands and changed the pivot you should be o.k.? Maybe?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 10-14-2007 at 10:12 PM. |
10-14-2007, 11:00 PM | #7 |
Re: can it be done?
I did it on my dads 67 a long time ago.I had to use the v8 motor mounts and move the trans mount back on the frame.The holes are all there.everything bolted up after I did that.
77 swb starting all over again. |
10-15-2007, 07:52 AM | #8 |
Re: can it be done?
Quick highjack - could the same be done with a 402? How about a 454?
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
10-15-2007, 12:56 PM | #9 | |
Chevy nut
Re: can it be done?
Yes.
