Old 10-15-2007, 01:09 AM   #1
evan
evan's Avatar
Rear diff issues
Lately I've been having some issues with the rear diff in my 78. It operates normally 95% of the time but every once in a while it locks the two wheels together and doesn't allow the outside tire to turn faster around corners.
Is this a common symptom of a dying rear end? When it gets worse will it just stay locked in the no-slip mode or will it cause both rear wheels to lock up (stop spinning) while I'm cruising down the road? Without pulling the cover off, is it possible for you to be pretty sure of what needs replacing?
Evan B.
evan is offline   Reply With Quote
Old 10-16-2007, 08:13 AM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: Rear diff issues
Its just guessing not pulling the cover off. Its not that bad of a job to pull just smelly.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 10-16-2007, 09:14 AM   #3
evan
evan's Avatar
OK, tomorrow's my day off so I'll see what I can see.
Evan B.
Old 10-16-2007, 11:09 AM   #4
hiway
Mad Scientist
Change the oil and also put the GM limited slip additive in it. Do a few tight circles in each direction to work it in. (Assumming the inspection doesn't look bad)
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 10-16-2007, 05:52 PM   #5
f.monroe
f.monroe's Avatar
Sounds like a GovLoc rear instead of a clutch type posi . I would say change the fluid but also make sure the tires are the same size and properly inflated . That can cause it to lock up and if there is a different diameter tire issue , it wont unlock correctly . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 10-16-2007, 07:19 PM   #6
evan
evan's Avatar
Thanks guys. I keep a close eye on tire pressures and they are all the same size. It's the stock open rear diff so will that GM limited slip additive still help?
Evan B.
Old 10-16-2007, 08:07 PM   #7
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
If your sure it's an open carrrier, the additive will do nothing really. If indeed you have an open carrier about the only answer then is... FOD (Foreign Object Debris) floating around inside getting between the moving parts locking things up. This happened to a buddy of mine in his '55 Belair back in 76, wasn't pretty at all. He was doing between 20 & 30 when it completely locked up. Pretty scary ride for about 30 seconds untill all motion ceased.
Wish you the best & be very careful driving, I would get it fixed asap.
Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 10-17-2007, 07:25 PM   #8
evan
evan's Avatar
Terry
Actually that's exactly what my buddy said would happen and why I started the thread. Sounds like a shocking experience.
I pulled the cover off today but unfortunately my camera died when I tried to take the first picture of the internals. I inspected it pretty carefully but couldn't find any blatant problems. I was told to expect small metal shavings kind of like the fine stuff left behind by an eraser and I did but I also found 8 larger pieces.
Do you think those are big enough to have been the ones that were causing the problem? I took it around the block and everything was fine so far.
Evan B.
Old 10-17-2007, 07:38 PM   #9
Pyrotechnic
Pyrotechnic's Avatar
That is NOT good.
Pyrotechnic is offline   Reply With Quote
Old 10-17-2007, 07:50 PM   #10
bigblock79
67 Chevy Stepside
bigblock79's Avatar
looks like you got some tooth missing on the ring gear
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 10-17-2007, 10:07 PM   #11
f.monroe
f.monroe's Avatar
Everything in the rear diff is necessary and the metal pictured came from somewhere . No matter where that was , it aint good . Frank
Old 10-17-2007, 10:48 PM   #12
MylilBowTie
Right turn Clyde
I'm thinking it may be the spider gears starting to go. It would have been nice to get a picture of the inside. They sell a kit to replace those. I believe it comes with the spider gears, bearings, shaft and bolt.
Old 10-18-2007, 12:39 AM   #13
evan
evan's Avatar
I was thinking about upgrading to a posi. Would doing that replace my currently broken parts, or would that be something different entirely?
Evan B.
Old 10-18-2007, 11:01 AM   #14
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
As long as you ring gear and pinion are ok, the limited slip will fix the problem. If there are pieces missing from them I HIGHLY recommend fixing them also.
It looks like spider gears to me also.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-19-2007, 09:01 PM   #15
evan
evan's Avatar
It was fine until tonight. It locked the two wheels together again. I guess I'll have to look into upgrades.
I'm considering the Moser eaton posi unit, unless somebody has a reason to avoid them.
Evan B.
Old 10-26-2007, 05:36 PM   #16
evan
evan's Avatar
Do I need a 30 spline unit???
Evan B.
