Old 10-16-2007, 04:18 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
need help with brake caliper studs
yesterday i changed out the disk pads on my brakes. when i tried to put the caliper back, the studs went in about 3/4 of the way and then stopped. i compressed the caliper pison all the way aswell as the fittings that the studs go though. this is happening on both studs. what is causing this?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 10-16-2007, 04:22 PM   #2
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: need help with brake caliper studs
Try changing the 2 studs around. (you probably already tryed that)
Put them in the opposite hole and see what happens. You may need to use a tap to clean up the threads
LOW DOUGH is offline   Reply With Quote
Old 10-16-2007, 07:46 PM   #3
crm318
crm318's Avatar
yea, i did switch them out. i also forgot to add that i also changes my wheelbearings as well. would that make any difference?
1972 Cheyenne
Old 10-16-2007, 09:55 PM   #4
71tahoe
71tahoe's Avatar
If you can get the pads over the rotor and the caliper on the spindle then the bearings shouldn't make a difference.
Pads swapped? Do both pads have holes for the bolt? Is one hole bigger than the other?
I don't have anything to look at so do you have a picture of what you are describing?
71tahoe is offline   Reply With Quote
Old 10-16-2007, 10:31 PM   #5
crm318
crm318's Avatar
i dont have a camera on me at the moment. yes, the pads have the same size holes and are identical to the old pads. i can see that the studs go straight through the caliper and pads, and and goes half way into the other side of the caliper with out threading it in. like i said, it can thread in about 3/4 of the way in and then it stops (its tough to get it past that and i dont want to strip anything). i cant see any obstructions.
1972 Cheyenne
