10-12-2007, 01:44 PM | #1 |
X-fer Blues (t-221)
So, pulling out of the parking lot at work Wednesday, and I hear a clunk, and my truck has a serious no-go condition.
Fortunately, I got my daughter on her plane to go back home before this all happend. So, locked the front axle in - no help. Can put truck in gear w nothing happening. Anyway, last night finished getting the X-fer out, took the inspection cover off, and everything looked OK. So I looked back at the tranny, and found the coupler sleeve with no teeth on the X-fer end... Looked back at the X-fer, and I wouldn't call them teeth on the input shaft, I'd call them stubs now... what a pisser! So now starts the search for a new X-fer or X-fer/tranny set-up. Might as well go NP205 now. Does anyone know if my existing drive shafts will work?
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
10-12-2007, 04:36 PM | #2 |
Re: X-fer Blues (t-221)
Sorry for your bad luck. Sorry don't know about the driveshafts. I believe the outputs are in slightly different areas height-wise so you could have a problem. Hopefully someone here knows for sure.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
10-12-2007, 04:56 PM | #3 |
I might have the 465/205 you need.You'll need a longer front driveshaft and maybe a shorter rear driveshaft.The crossmember and torque bracket will also have to be moved back some.The crossmember is also different but I dont know if you can make the existing one work.I might also have one of those crossmembers from a NP205 equipped truck.
Dustin Last edited by 1969k10stepside; 10-12-2007 at 05:03 PM. |
10-13-2007, 10:28 PM | #4 |
Aluminum slot wheels rule...
your gonna need a longer front shaft and shorter rear shaftm figure on moving the t-case crossmember back 2 inches. I used the Rockwell x-member with the 205, works fine, no problems.
10-13-2007, 11:13 PM | #5 |
Overdrive club
I hated my rockwell,thing sounded like a jet airplane!!!!!!!LMAO!!!!!
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
10-14-2007, 12:24 AM | #6 |
LOL.Mine never sounded like that,but it was just straight pipes so that concealed all other noises.. Mine never leaked bad either.It had a slow leak,but was never low on fluid.I guess the previous owner took good care of it.Heck,it only has 94,000 miles on it...
As soon as I finish building a 355 for the truck,it and this heavy tranny/t-case combo is going back in. |
10-14-2007, 01:25 AM | #7 |
taht sucks Mine did the same thing now Im replacing it with a nv4500 and a 205. I thought I had tore the trans up and it had just been rebuilt. i dont think you will miss the jet plain sound.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 10-14-2007 at 01:26 AM. |
10-15-2007, 07:19 AM | #8 | |
10-15-2007, 05:43 PM | #9 |
I've got 2 T-221's stashed away, one looks like new internally.
10-16-2007, 10:59 AM | #10 | |
Dustin - PM sent
10-16-2007, 04:48 PM | #11 |
Who said I was selling them???
10-16-2007, 05:34 PM | #12 |
I just rebuilt my T221 if you have any questions, and it's fun to hear everyone's feelings about the "airplane" hum; I agree 1969k10stepside; my straight piped cherry bombs seem to numb most everything.
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
10-16-2007, 08:00 PM | #13 |
PM returned..you should be running around with a 465/205 in a few weeks...no wheeling till then though
10-17-2007, 06:41 AM | #14 |
Keep me updated Dustin. THX
