Old 10-18-2007, 02:43 AM   #1
evan
evan's Avatar
lwb to swb
Is it possible to modify this generation of truck from LWB to SWB like it is with the last generation? The thread in the faq section got me thinking about it and while I was under my LWB today I took some rough measurements.
(The two 7" squares are the leaf brackets.)
Evan B.
evan is offline   Reply With Quote
Old 10-18-2007, 02:50 AM   #2
abebummy26
abebummy26's Avatar
Re: lwb to swb
I know a guy who shortened a 4x4 frame. I have no details what so ever though his son just mentioned it I didn't have time to ask questions.
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 10-18-2007, 03:04 AM   #3
crawdad
crawdad's Avatar
Re: lwb to swb
You might want to check out this link and see if it helps any. http://www.73-87.com/7387garage/chas...lwb_to_swb.htm
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 10-18-2007, 09:20 AM   #4
evan
evan's Avatar
Re: lwb to swb
Good stuff, thanks.
Evan B.
Old 10-18-2007, 06:34 PM   #5
kevinr1970
Re: lwb to swb
Look for a post from OJOE about making a crew cab short bed.
For doing the conversion he took the rear section of a short bed frame and "grafted" it onto the long bed frame using the bolt holes from the cab mounts as locators.
It might be easier to do with a 1-ton frame because of the frame differences but I would think you could do it with a 1/2-ton frame too.
Not much cutting and if you line up the cab mount holes your gauranteed to get it back together square.
Of course this requires having a short bed frame available to you? I have a 4x4 short bed that has a bent frame in the front. I have been resisting getting rid of it thinking I may be able to do a 4x4 crew cab short bed conversion but the signifigant other is tightening the screws...
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 10-18-2007, 08:01 PM   #6
evan
evan's Avatar
Re: lwb to swb
I've actually been keeping my eye out for a shortbed frame in my area but no luck so far.
Does anybody have any pics of how the rear bumper is attached on swb trucks?
Evan B.
Old 10-25-2007, 07:24 PM   #7
bluex
bluex's Avatar
Re: lwb to swb
Take 14" out of the frame behind the cab.
Take 4.75" off the rear.
Replace the parking brake cables, brake line and gas tank with a 16 gal.
Shorten Driveshaft
Drive it. Its not as hard as it sounds. The best thing to do is have the short bed on hand to help you set up your measurements. The 2nd set of bolt holes from the rear will line up with the short bed and help you with the measurements. The rest will have to be drilled.
bluex is offline   Reply With Quote
Old 10-26-2007, 12:37 AM   #8
canadianc-10
Re: lwb to swb
hey evan, how far are you from brooks. ab?
canadianc-10 is offline   Reply With Quote
Old 10-26-2007, 01:03 AM   #9
evan
evan's Avatar
Re: lwb to swb
Thanks for the input bluex.
I'm in Saskatoon, so I think that means about 6 hours.
Evan B.
Old 10-26-2007, 05:36 PM   #10
Coronas56
Coronas56's Avatar
Re: lwb to swb
This should help ya out..........http://www.67-72chevytrucks.com/vboa...d.php?t=123624
Coronas56 is offline   Reply With Quote
Old 10-26-2007, 05:47 PM   #11
evan
evan's Avatar
Re: lwb to swb
Originally Posted by Coronas56 View Post
That's the thread I was referring to in the first post. That info applies to 67-72.
Evan B.
