Old 10-18-2007, 01:09 AM   #1
abebummy26
abebummy26's Avatar
Question 12 bolt
I found a 73-78 chevy big 10 truck bed made into a trailer. I looked underneath it because I figured it had a 12 bolt and I was right. I'm pretty sure I could bid on it for next to nothing and get it. Should I, or not? I would also like to know how to decode the axle to tell if it is a positrac. If it is I would be a lot more tempted to buy it. I am thinking about getting it for a drag truck when I get older. The truck bed is wasted basically the only thing I would take off of it would be the tail lights because they are the chrome strip around the edge ones.
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 10-18-2007, 01:54 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: 12 bolt
I'd grab it if you can get it for cheap. If anything, you've bought yourself is a good 12 bolt housing and axles to work with. I would just get a good aftermarket posi unit, your choice gear ratio if the ones in there are in bad shape or not what you want, and have it built with all new bearing, seals, and whatever else it needs.
If you get it cheap, you can probably sell the trailer for scrap metal and get some money back.
Pyrotechnic is offline   Reply With Quote
Old 10-18-2007, 02:20 AM   #3
abebummy26
abebummy26's Avatar
Re: 12 bolt
Yeah that's what I was thinking pull the trailer to the scrap metal yard and pull the 12 bolt and springs load it in my truck grab the lights, wheels, and tires (for rollers) and scrap everything else. Most big 10s had positrac right since the were meant to haul stuff?
-Lincoln
Old 10-18-2007, 10:58 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: 12 bolt
Why are you wanting to get a 12bolt so desperately? What are they worth in your neck of the woods?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-18-2007, 11:52 AM   #5
abebummy26
abebummy26's Avatar
Re: 12 bolt
I'm not desperate but I if I can get one for free almost if I scrap the rest of the trailer. I figured that would be a good deal for me. I have never seen one for sale, but I haven't looked.
-Lincoln
Old 10-18-2007, 12:41 PM   #6
Captkaos
Captkaos's Avatar
Re: 12 bolt
They aren't any stronger than a 10bolt. 10Bolts have beefier pinion shafts.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-18-2007, 12:55 PM   #7
abebummy26
abebummy26's Avatar
Re: 12 bolt
Thanks for the info that nixes that idea tyvm.
-Lincoln
Old 10-18-2007, 02:02 PM   #8
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Re: 12 bolt
I seem to remember reading somewhere that you can replace the truck gears with car gears (and car pinion bearings) in the 12-bolt to get the bigger pinion. Anyone know for sure?
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 10-18-2007, 02:08 PM   #9
Pyrotechnic
Re: 12 bolt
The 10 bolt gets bad rap from the 7.5 inch ones that are very easily grenaded but the 8.5 units in these trucks are quite strong.
My heavy half GMC which is the equivalent to a Big 10 didn't come with a posi. All Big 10 means is 3/4 ton springs, big brakes, and heavy duty emissions.
When it comes down to it, which do you guys think is ultimately stronger? The 10 or 12 bolt ? I know a 10 bolt is plenty strong enough to where finding a 12 bolt isn't necessary, but I'd just like to know which is ultimately stronger.
Old 10-18-2007, 03:05 PM   #10
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: 12 bolt
In my neck of the woods I see 12 bolt rear end housings go all day long for 4-500 bucks, without gears... with gears they may bring even more.
xtreme80 is offline   Reply With Quote
Old 10-19-2007, 12:19 AM   #11
abebummy26
abebummy26's Avatar
Re: 12 bolt
ttt
-Lincoln
Old 10-19-2007, 12:11 PM   #12
Captkaos
Captkaos's Avatar
Re: 12 bolt
Not without some machine work.
BTW there is a guy on my forum selling a 12bolt for $75...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-19-2007, 05:15 PM   #13
Poopski
Poopski's Avatar
Re: 12 bolt
Is the machine work to do it very costly?
1985 Chevrolet C10 305 2wd LOOOOONG Bed
Broke as a joke and funny as a funeral
Poopski is offline   Reply With Quote
Old 10-19-2007, 06:51 PM   #14
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: 12 bolt
If its for your truck you already have the best rear for strength. Assuming that your K30 still has its original rear. I could see getting a 12 bolt for a car setup. But with the 14 bolt sf/ff out there I don't see a need for a 12 bolt. Cheaper to buy and hold more power vs the 12 bolt.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 10-20-2007, 01:50 PM   #15
Captkaos
Captkaos's Avatar
Re: 12 bolt
No idea if that is possible, just know they aren't the same.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-20-2007, 05:23 PM   #16
Nolowrider
Nolowrider's Avatar
Re: 12 bolt
Don't think so. The car pinion shaft is thicker (1.625") the truck is something like 1.4. I ordered a car set by accident and it would not fit.
Nolowrider is offline   Reply With Quote
Old 10-20-2007, 09:51 PM   #17
abebummy26
abebummy26's Avatar
Re: 12 bolt
No It wont be for my truck. I would be thinking about using for a future project maybe a drag truck?
-Lincoln
Old 10-22-2007, 06:24 PM   #18
abebummy26
abebummy26's Avatar
Re: 12 bolt
ttt
-Lincoln
Old 01-08-2008, 05:33 PM   #19
abebummy26
abebummy26's Avatar
Re: 12 bolt
I really need information on this. I know this is an old thread, but If anybody knows anything more that would be greatly appreciated. Btw I am going to school to be a machinist, so machine work is minor, to me anyways lol.
-Lincoln
Old 01-08-2008, 06:03 PM   #20
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 12 bolt
12 bolts look better.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-08-2008, 06:07 PM   #21
abebummy26
abebummy26's Avatar
Re: 12 bolt
lol thats true. Not exactly the answer I was looking for but I guess its a start.
-Lincoln
Old 01-08-2008, 06:13 PM   #22
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: 12 bolt
I say go for it. If you can get it cheap and use it.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-08-2008, 07:44 PM   #23
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: 12 bolt
X2
Malo83 is offline   Reply With Quote
Old 01-09-2008, 11:30 AM   #24
baknblk
baknblk's Avatar
Re: 12 bolt
in my neck of the woods a 12 bolt is hard to find..use to be a big deal back in the years..12 with a 4:11 was what everbody wanted ..didnt any of u guys use to race.
baknblk is offline   Reply With Quote
Old 01-09-2008, 11:37 AM   #25
Alex1
Alex1's Avatar
Re: 12 bolt
Find me a good Dana 60 and I'll trade you my 12 bolt...LOL the truck 12 bolt is not worth putting money into - not if you are going to make any power.
Alex1 is offline   Reply With Quote
