Old 03-01-2004, 12:27 PM   #1
chargedstang89
Bolt Pattern/Wheel Help! (4x4)
I need a new set of wheels for my truck, but don't know the proper backspacing or bolt pattern. I have a 1985 GMC Sierra 4x4 1/2 ton. I know the wheels are 6 lug, but I just want to confirm that they are 6x5.5. Also...what backspacing do I need? Brakes are all factory...discs up front & drums in the back. Any help would be great.
Thanks,
Josh
chargedstang89 is offline   Reply With Quote
Old 03-01-2004, 12:42 PM   #2
CRRoy71
I do know that they are 6 on 5.5, but someone else will have to help with the back spacing.
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 10-15-2007, 11:01 AM   #3
dirtybird1
dirtybird1's Avatar
Re: Bolt Pattern/Wheel Help! (4x4)
Bringing this back from the dead. I have an 84, so practically the same. What is the center hole size? What should backspacing be? Thanks
Matt
dirtybird1 is offline   Reply With Quote
Old 10-17-2007, 03:29 PM   #4
dirtybird1
dirtybird1's Avatar
No one?
Old 10-17-2007, 05:58 PM   #5
Duro5341
Duro5341's Avatar
It is a 6- 5.5 bolt spacing, usually when buying rims it'll say for chevy truck. Because the center flange has to be bigger to accomidate the hub assembly
As for backspacing....no clue
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 10-17-2007, 06:37 PM   #6
ChaseDale3and8
ChaseDale3and8's Avatar
I believe the backspacing on a 6 lug 5.5 is 5". ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 10-18-2007, 09:48 AM   #7
dirtybird1
dirtybird1's Avatar
Thanks!!
Old 10-18-2007, 10:52 AM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
AFAIK all factory Chevy truck rims use a 4" backspacing regardless of rim size (7 or 8" wide)
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-18-2007, 06:08 PM   #9
ChaseDale3and8
I believe that he was asking about aftermarket rims. At least that is the way that I understood the question. I'm running aftermarket wheels on both of my trucks. One has 16x8s and the other has 15x10s. Both have a 5" backspace. Hope this helps. ...Joe
