Old 10-17-2007, 12:57 PM   #1
michael bustamante
michael bustamante's Avatar
rear ends
Ok guys here`s a question for you. I was given a 1960 long wide 3/4 ton rolling chassis. 1st; how hard is it to convert the torsion bar suspension from 3/4 ton drum to half ton disc? ( possably using 1972 A arms and spindles) 2nd; what gear ratios were available in the 1960 3/4 ton rear end? ANY info is relly going to help so thanks in advance. Mike
1967custom
michael bustamante is offline   Reply With Quote
Old 10-17-2007, 04:12 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: rear ends
I'm not sure if the frame widths from a half ton to a 3/4 ton are the same. If it is the same, what you can do is use the front suspension from a 73-87 truck. That's what I have on my 62. My truck has a rearend from a 72.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-17-2007, 04:27 PM   #3
Captainfab
60-66 Nut
Re: rear ends
I've not done a suspension swap like this on a '60-'62, so I don't have any detailed info for you. At a minimum you will need to change the A-arms, but I don't know if the '60 crossmember can accomodate a coil spring. You may have to change the crossmember also. Then of course there is steering to deal with also....tie rods, idler arm, etc. Might also be a good time to upgrade to power steering also. You can use parts for any of this from '71 to '87 GM pickups.
Concerning the rear end ratios available in the Eaton HO72, the most common one that I've found is 4.57. The 4.10's were also available, and I'm not sure what else. I haven't been able to find a source for aftermarket parts for the rears, such as gears, lockers, etc. If you by chance have a Dana 60 rear end (not very commom) you have more to choose from in aftermarket parts available.
Old 10-17-2007, 06:44 PM   #4
rodnok1
rodnok1's Avatar
Re: rear ends
There are some changes between 60 and 64+ frames/suspension. I would do some searches here about it. Some things interchange and some will not work.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 10-18-2007, 12:59 AM   #5
62ChevyStep
62ChevyStep's Avatar
Thumbs up Re: rear ends
Ditto on what jchav62 said, I did a 86' chevy 1/2 ton front (spindle to spindle) on mine with a 72' 3.73 posi rear (1/2 ton truck). 350/700r4 on my 62'.
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 10-18-2007, 09:26 AM   #6
jchav62
1962 C-10
jchav62's Avatar
Re: rear ends
I used to have a posi rearend too, til I broke the carrier. Now I have a 3.73 peg-legger...Until I find another posi carrier to put back in... Nice to see New Mexicans on here...
Joseph Chavez
Old 10-18-2007, 11:49 AM   #7
michael bustamante
Re: rear ends
thanks for your help guys. I knew you `d come thru for me. I got access to a 72 front end and a 3.73 posi. neighbor Joe C, should I use the front crossmember also when converting the front end to 1/2 ton disc or can I just switch spindles and keep the torsion bar suspension? Also guys thanks for the rear end info. what should I look for to see if its a dana? Someone told me it was.
1967custom
Old 10-18-2007, 12:35 PM   #8
62ChevyStep
Talking Re: rear ends
I would personally do a complete crossmember swap (spindle to spindle) IMO easier, more cost effective down the road (matching year parts etc).
For rear end ID, this site helps: http://coloradok5.com/axleguide.shtml
OH yeah -
Old 10-18-2007, 12:37 PM   #9
62ChevyStep
Re: rear ends
I agree, good to see more of US popping up on the radar.
Old 10-18-2007, 02:58 PM   #10
michael bustamante
Re: rear ends
Sounds like a plan. So i got my winter project now. Kiss my garage space goodbye. thanks portales 62 chevystep. appreciate it
1967custom
Old 10-18-2007, 03:55 PM   #11
62ChevyStep
No Problem, always glad when I can be of assistance, always better than trying to reinvent the wheel. Don't hesitate to post ANY questions as everyone on here is more than willing to share information.
Old 10-19-2007, 11:28 AM   #12
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
Re: rear ends
one more NM person to add to the list...we should have a meet next spring or fall ----->when my truck will be ready! We could do a drive on 14 or through Valle Calderas or something
Sequoyah is offline   Reply With Quote
Old 10-19-2007, 11:47 AM   #13
michael bustamante
Re: rear ends
good idea. a bunch of roaring Chevy trucks going thru the Jemez. I love it
1967custom
