Old 10-18-2007, 02:49 PM   #1
Tim64
Tim64's Avatar
Trans opinions
Hey Guys,
I’ve seen a couple threads regarding early 80’s S-10 T5 transmissions being put into our year of trucks. I talked with Tom Langdon @ Langdon’s Stove bolt briefly about it. He said he could sell me a trans that was geared right for my application. I’m thinking shipping on a trans would be pretty crazy, so I was thinking of trying to find one close to home. I would like to hear from someone that has done this. I would like to know what all I have to change and approximately how much money I’m going to have to put into this. My truck is a 230 3spd. I want to make it more drivable at highway speeds. If there is something better to switch to please give me your opinions.
Thanks,
Tim64 is offline   Reply With Quote
Old 10-18-2007, 03:19 PM   #2
courage 80
Re: Trans opinions
I just finished a t-56 (six speed out of a trans am) swap. It is wonderful at highway speed. I have 31 inch tires so I lose some in 6th gear. But I can cruise in 5th all day. AND if I go back to the smaller tires I wont have to mess with the rear end.
I had heard that the t-5 out of the S-10 is not as strong, but ?
I had to get a flywheel to mate the t-56 clutch and bellhousing to work with the crank on my engine (about $300 +/- $50). Then I fabbed the trans mount for the t-56. You want to see if you are going to get the hydraulic clutch, bellhousing, clutch plates, and slip yoke with the trans.
I would say that I have 1500 or so in the swap, to include the trans.
courage 80 is offline   Reply With Quote
Old 10-18-2007, 03:36 PM   #3
Tim64
Tim64's Avatar
Re: Trans opinions
I had a friend tell me to change it over to a powerglide, and that would bolt right up. What do you guys think about that idea?
Old 10-18-2007, 04:23 PM   #4
1966gmc
Why does it taste purple?
1966gmc's Avatar
Re: Trans opinions
It'll bolt up but remember you will only have 2 gears.Will a th350 bolt up to the inline 6's? I would assume they do. 700r4,th400 so many options.Im def goin auto this winter. SBC 350+trying to powershift 3spd=teh suck
1966gmc is offline   Reply With Quote
Old 10-18-2007, 06:25 PM   #5
Iron-Butt
454 club
Iron-Butt's Avatar
Re: Trans opinions
I have used turbo 400, 700r4 and 200r in mine autos conversions. I like the 400 as no kick down cable.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 10-18-2007, 11:44 PM   #6
Real_McCoy
Real_McCoy's Avatar
Re: Trans opinions
What is involved in the TH400 swap? I have an I6 (230?) with a 3 on the tree currently. I need to replace my tranny soon. First gear in the 3 speed is making a loud clanking sound.
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline   Reply With Quote
Old 10-19-2007, 12:06 PM   #7
Baby Blue 66
Re: Trans opinions
You mentioned that drive ability at highway speeds is an issue. A power glide, TH350, TH400 and your current 3 speed all have the same final gear ratio. I would think that you want either an OD, 200R4, 700R4, or or a manual box with OD. Or you could change to a numerically lower rear end gear or go with taller tires. I myself have a pretty thrashed 700R4 with 3.73 rear and 28in tall tires, makes for a nice combo. The hardest part of this install is the TV cable and a new drive shaft, you also need a flex plate and possibly a new tranny x-member, but is should bolt right up to a six.
Baby Blue 66 is offline   Reply With Quote
