Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-25-2007, 05:42 PM   #451
Frizzle Fry
Frizzle Fry's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Also got more trailer fenders for my inner mods today
Frizzle Fry is offline   Reply With Quote
Old 09-26-2007, 08:47 PM   #452
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I can't believe how cool this thing is. I love that it is looking like something that GM could've made. I got into the burbs because i saw one I really liked that had been bobbed 10" behind the rear wheels but this is a whole different level of difficulty and style. I'm curious if you went with a one piece drive shaft or have the carrier bearing style still. guessing by the relief in the floor it looks to me to be 1 pc.
RunninLo is offline   Reply With Quote
Old 09-26-2007, 09:56 PM   #453
68 short step
man i wished i lived closer to ya, i wanna see this one in person..
68 short step is offline   Reply With Quote
Old 09-27-2007, 11:47 AM   #454
Frizzle Fry
I've seen a couple done that way (bobbed) and they do look good in their own way. I've also seen them turned into 104" wheelbase "hardtop Blazers." I lost count on how many 55-59, 60-66, and 67-72 Tahoes and Blazers I built in Photoshop I finally decided on these dimensions because they worked well in Photoshop and there's no denying the SWB truck look good
Yes I did go with a one-piece driveshaft. It was the same cost as having my stock two-piece cut and rebalanced, but much stronger (good for 600 hp).
Let me know if you ever venture up this way and you have an open intive.
Old 09-27-2007, 12:21 PM   #455
earl87gta
earl87gta's Avatar
You have mad skillz I love It.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-18-2007, 03:22 PM   #456
wagonhoe
wagonhoe's Avatar
Cheap porn doesn't make me drool as much as I have reading this build...
1969 C10 Suburban, 396cid, Turbo 400, 9" F***, Disk brakes all around
1968 C10 Suburban, 350cid, 700R4, bent frame
1968 C20 Suburban, no motor, trans or interior (SOLD!)
1953 Packard Ambulance
1992 Caprice wagon
wagonhoe is offline   Reply With Quote
Old 10-18-2007, 08:49 PM   #457
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Any Update's, We are going thru Withdrawal...............
Thanks, Rick
toomanytoyz is offline   Reply With Quote
Old 10-19-2007, 05:42 PM   #458
Frizzle Fry
Me too Been pretty busy but I've managed to tackle some little things here and there. I posted some more pics of the inner fender mods in the susp forum you may or may not have seen.
I did some minor stuff like POR-15 the Leaf guard I made for under the cowl and install new door seals. Also made the 3rd door sill plate fit and started working on shortening the lower trim.
...and I did a little rust repair on the 68 clip:
Hammer/dolly'd this area to close it up better (common dirt collector):
Then welded it up:
And ground the welds a little. POR-15 will be applied later:
Old 10-19-2007, 05:46 PM   #459
Frizzle Fry
and put 'er on:
Old 10-19-2007, 07:43 PM   #460
SCOTI
SCOTI's Avatar
That patch looks like it fit much better than the one n2billet & I did for a buddy of mine @ work (he's also a board member now ). If I aligned the wheel-opening 'body-lines', it was short @ the grille area; fit it properly @ the grille area & you'd fight the opposite end.
It gave a me fits before n2billet got involved & we decided to align it @ the most visible point (the wheel opening) & try to split & fit @ the opposite end. In the end, you'd have to look for the repair but it was a pain in the a##!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-19-2007, 08:49 PM   #461
PDomes7277
PDomes7277's Avatar
Thats going to come out a beauty...Keep up the good work. Love to see the progress.
1972 Chevy C-10 SWB
- 5.7/4L60E
2011 GMC Sierra - Daily
1977 Harley Super Glide FXE Shovelhead
PDomes7277 is offline   Reply With Quote
Old 10-19-2007, 10:03 PM   #462
Frizzle Fry
I had the same issue! I ended up splitting the patch "cup" there by grille side and filled it back in with weld. Matching the wheel arch is obviously more important. Mine turned out pretty good where I split it but it's not perfectly vertical there... the bumper will cover that area anyway.
Thanks!
Old 10-20-2007, 12:14 AM   #463
SCOTI
SCOTI's Avatar
Thanks!
That's exactly why I suggested to my buddy that a bumper would 'work' better than a roll-pan . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-20-2007, 09:40 AM   #464
dan468
dan468's Avatar
I'm very new to body work...which grinding tools do you use to grind your welds down. They look amazing.
thanks
dan
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 10-21-2007, 11:27 PM   #465
Frizzle Fry
I grind most of the weld with a grinding wheel on a 4.5" angle grinder, then 4.5" flap disc, the 60 grit DA. I'm no pro, that's just what works for me.
Old 10-22-2007, 12:07 AM   #466
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
"I'm no pro"... Holy crap, there is some amazing fabrication work in this build. I'm not sure how I missed this thread until now. If I ever decide to build another truck I know where to come for information... Mike's build threads.
Awesome job. Keep it up.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 10-22-2007, 09:13 AM   #467
dan468
dan468's Avatar
Do you have pictures of each? I'm like a caveman...
Thanks!
68 C-10
Build thread
Old 10-25-2007, 01:31 AM   #468
Frizzle Fry
Thanks C10-Driver.
Dan468 I'll see what I can come up with.
Old 10-25-2007, 05:31 PM   #469
wagonhoe
wagonhoe's Avatar
I wanna be like you when I grow up Frizzle Fry. I'm 44 now, any idea how much longer that might be?
1992 Caprice wagon
Old 11-16-2007, 08:33 PM   #470
Frizzle Fry
-14 years
Old 11-16-2007, 08:50 PM   #471
Frizzle Fry
I know I've let this thread get pretty buried lately. Life happens, even to me...
But I stoked the fire today. Finally wrapped those hoops in some rubber. Now I need to get my tubs done so they'll tuck properly!
Specs:
22x9 w/5.5" BS (5" BS would be better but they stopped making them) 305/40/22
20x8.5 w/5.25" BS
255/45/20
Pics...
Current ride height (pre-tubs):
...and sitting on the stock inners (front not rear) This will be about ride height after tubs and exhaust:
Still need to grind the front hubs a little to fit the center caps:
Old 11-16-2007, 09:00 PM   #472
5150
C10 Club Tennessee
5150's Avatar
Looks awesome to me!!!!!!!!!!!!!!!!
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-16-2007, 09:06 PM   #473
Hart_Rod
Hart_Rod's Avatar
I'm jealous!!!!!
Hart_Rod is offline   Reply With Quote
Old 11-16-2007, 09:22 PM   #474
babyblueoval
babyblueoval's Avatar
Hey Frizzle,
If you're gonna go lower are you gonna raise that gas tank and if so, what are your plans? I'd hate that to be one of the lowest things on my suspension.
Your truck is turning out amazing. I feel like my regular Blazer body is gonna be boring by comparison. lol
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 11-16-2007, 09:28 PM   #475
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
