Early Classic and Air Ride tech
Ok guys, I just removed the rear setup on my 69 truck. I was wondering if it will fit a 2 wheel drive blazer. I have the notch, panhard, and shock relocators?
Re: Early Classic and Air Ride tech
blazntn,
I got your PM and I'm pretty sure it didn't answer this question. I do believe I've read somewhere that, other than the obvious length difference, the frames are the same as far as the hoop and mounting locations go. The trailing arms will be shorter and the distance from the cab mounts to all the suspension components will be less. You planning on using your old set-up on Chad's Blazer? That would be very cool.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
Yep, that will all fit.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
The trailing arms are not shorter, they are the same length on Blazers, short beds, and long beds of the 67-72 era.
ok next question, does anyone know where I can get directions on how to install the bolt in notch and shock relocators.
Oops. Sorry 'bout that. I thought they were shorter.
They just mount closer to the front?
Here's a thread on the C-notch:
http://67-72chevytrucks.com/vboard/s...d.php?t=195566
Thanks that helps!
