Old 10-20-2007, 10:27 PM   #1
geoman
Disc conversion
Ok, I did a search and read for awhile so let me make sure I get this straight.
I just bought a 67 with drums on front with six lugs. To convert to discs (I am on a budget), I just look for someone selling or parting out a 71-72 model, correct? Just need the spindle and rotor? I will be buying new bearings, and ball joints for my local store.
Also, I can get some axels from one of the vendors with the 5 lug and buy some shoes and drums to fit?
I hope I got this right.
Thanks for any help.. I am still learning but reading alot.
Mike
geoman is offline   Reply With Quote
Old 10-20-2007, 10:48 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Disc conversion
You aren't limited to a 71/72. You can get the front suspension from any 73-87 truck or 88-91 'burb. You can use the whole crossmember or just swap the control arms into your existing crossmember. I am not 100% on the rear, but someone will chime in and confirm whether or not that can be done. BTW, to the board!
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 10-21-2007, 10:14 AM   #3
70GMCer
70GMCer's Avatar
Re: Disc conversion
Go with the 73-87 suspension.....much better.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-21-2007, 11:22 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Disc conversion
73-87 Ball joints etc. are also cheaper(at least where I priced them.You do have to match the ball joint to the spindle used.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
