What's the best years for a parts truck?
I have a Mustang restoration shop, but a family friend has asked me to help her son locate and restore a '67-72 Chevy pickup. I found a '67 SWB that was in very good condition (very complete, reasonably straight and no rust) for $2000 so they bought it. However, it's an I6 with a 3 on the tree, and he wants a V8 Auto. It's also devoid of power anything and he would like to have PB and PS. I told him that I thought a later model parts truck might be the best way to go for upgrade parts, but since I don't do much with Chevy pickups, I thought I would ask you guys for your expertise.
I have located a wrecked '96 GMC 1500 SWB. It's got a Vortec V8 with an automatic transmission. Is this a feasible swap? What about the disc brake spindles, or perhaps even the entire suspension and steering subframe? Steering column? Brake booster? Auto brake pedal setup? If this truck isn't a good parts truck candidate, what would be good to look for? Thanks. Here are some photos of the '67. The odometer shows 91k. ![]() ![]() ![]() Last edited by bighorse; 10-19-2007 at 12:39 PM. |
![]() Join Date: Jul 2003
A 1971 or 1972 model will be great for the disc brakes, 5 lug conversion, and the PS, PB.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Re: What's the best years for a parts truck?
I'd go for a 72 if you need some interior pieces, it's a little nicer IMO.
71 or 72 for disc brakes and whatnot as stated above. There are better engines than a vortec 350 if you're going to go to that much effort...but if you can get it cheap, its still a good engine. |
I know for the front suspension/brakes, the 73-87 chevy's is a direct swap with little to no mods. It sounds like sometimes the mounting holes aren't all there in the 67-72 frames. I know you said the kid wants a v8, but there are a lot of option that could be done with the inline. There are a lot of inline 6 people here who could give you some insight on what can be done to those enigines. I know more people on here will chime in. Good luck
We're definitely going to swap to a V8. We can get the entire '96 truck for $1000 and I don't think we could touch a better complete drivetrain for that price. Would the steering/suspension components be of any use at all?
Weekend Warrior
The problem with the vortec set-up is all the electronic BS & the front end/disc brake/power set up won't be any easy swap, it will probably take quite a bit of fabrication.
'71-'72 C-10 will have a disc brake front end - you can swap the whole front crossmember over to the '67. you can also use the crossmember from a '73-'87 C-10, but they switched over to 1" thick rotors on some models in the late 70's. The early '73-'76 will def. have the 1.25" thick rotors and you'll have to look for a C-10 with "HD brakes" if you go with something in the '77-'87 range. '71-'72 rear will bolt in and give you the 5-lug - or you can get axles from "early classic enterprises" Powersteering - a box from a '71-'87 should bolt in with no problems - although some '67 frames need a small "notch" or a spacer between the chassis and the steering box. I would get a stock style Auto Steering column - again from an auto '67-'72 Motor/tranny - Just go with a nice 350/350 or 350/700R4 for the overdrive gear. You should be able to pick up a donor '73+ truck with all the suspension, steering, brakes, motor and trans for much less than 1k - just get a good running motor and clean it all up.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 10-19-2007 at 01:34 PM. |
Best parts truck would be a 71 or 72
2nd best would be a 73 - 87 A 96 truck for 1000 -- really depends on how bad the wreck was and the mileage on the motor and tranny--- might have some salvageable seats or something, but nothing else is really compatible without some fabrication ---- then you have a bastard child that no one can ever get the right parts for later on when stuff needs to be replaced. Then tell your client's boy that a lot of girls out there can only drive autos too, so he's not alone with his lack of coordination-- (just kidding) But a 350/350 combo can be done for $1500 thats freshly rebuilt without having to dispose of some "light rollover" hulk and wrestle with the electronics to get it to work. Thats a decent starting point for a nice truck there---- incompatible parts can be made to fit anything, but with the prices these trucks get when they are done right, why mess with a proven formula? Last edited by streetstar; 10-19-2007 at 10:23 PM. |
![]() Join Date: Feb 2004
If you can get the complete truck for $1000 go for it, the swap is not hard if you have the entire truck just remember not to cut any wires, unplug them all during the transfer. The front clip comes off complete with around 10 bolts so the makes it easiest for putting in the newer engine.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
I have a radical idea!
First of all
![]() For the price, I would definitely get the Vortec 350 truck. It would cost a lot to buy any kind of EFI set-up and OD transmission, and if you can get the whole drivetrain for $1000, you're money ahead, providing its not a worn out beat down engine/drivetrain. You can buy new ball joints and tierod ends for a 71-72 and just change out the spindles. There is no need to swap the whole crossmember. A lot of people say "Just change the crossmember, it's easier" but chances are if you swap a crossmember from a used 70's or 80's truck, you need new ball joints and tierod ends anyway if you really want to do it right.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Use the search function to confirm this, but my memory beleives that the front brake system can be made to work also. Memory says that it requires 3/4 2wd 67-72 lower control arms. Then use the upper and lower ball joints fron the 96 donor. You now have a modern brake system. But that seems like a lots of mis-matching parts when you could find a 71-87 donor and use the many times proven method.
Jason |
Car Knocker
Welcome from central Arkansas. You did not state how much money they were willing to spend. I'm sure you know that there are many parts available aftermarket that will work to convert over to power brakes if the money is there. I would find a 71-72 model for parts for easy swap but as you know they will be 35 years old. I too remember back in the day about using the 90 something spindles on these trucks. Have you had a chance to search yet.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
Thanks for the welcome. They have some money to spend, but they are depending on me to keep the project as reasonable as possible. What he wants in the end is a nice, dependable, safe truck. I learned a little more about the '96 today. It's got 160k on the drivetrain and the frame is bent. I have a small fleet of tow trucks, so disposing of the leftovers is not a problem. You never know what's going to show up in the impound...I might snag a decent donor truck for them that way if we're patient. I did a tow today for a guy who has a small boneyard of '70-72's. I may see what he has available for the steering/suspension.
Does anyone have any experience with mounting a '67-72 cab and bed on a late model chassis? |
#13 | |
Your into Mustangs primarily right? That would be like putting a Boss 302 body on an F-150 4wd chassis and lifting it skyhigh ---------- interesting, but not quite right Well, maybe not that drastic, These trucks are not in the Boss Mustang league as far as value right now, but check ebay or some classifieds -- 2k was a very decent deal on that truck, and it looks pretty clean -- far better to go with a resto-mod look than to change the thing completely. As others have already said, the parts are out there to add disc brakes, etc. to the truck --- they actually came with them in 71 and 72 -- the 73-87 disc conversion is easy, new axles are just a C-clip away to match, any pwr steering box up til 87 will work --- there is just not much logical reasoning behind turning a nice truck into a hacked up franken-truck. Unless someone is into building a show truck that lays frame, some type of big hp pro street truck, or the like - it would be unwise to do much to that truck that couldnt be reversed relatively easily If your client wants a "nice, safe, dependable truck" - maybe they should just get him a clean '96 or '98 short wide and call it good |
Chevy nut
I am using a 77 for suspension and brake parts. The axles out of the 77 fit into my 69 axle case. Both are 12 bolt. The 69 has coil springs with over loads. The 77 is a leaf spring set up. The 77 also has 11" drums. I am using the front spindles and all brake parts from the 77. I think the disc on the front are 12"...I could be wrong. Just like the 67 your people have...mine has no options. I am keeping it that way. I dont want any power robbed from the motor.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
#15 | |
We looked for several weeks and found a lot of rust buckets for not much less money, so I knew that $2k was a decent price for the '67. If it was mine, I would restore it to original, stock condition (that would be SO easy with this truck). However, I also understand why that does not appeal to a 17-year old boy. Thanks for all the input...I'll certainly be back with more questions as we progress. |
#16 |
Old Duffer
![]() Join Date: Mar 2003
Talk the boy into an '80's V8 "hot rod" truck and buy the '67 to restore.
Maybe I'm getting mellow in my old age, but it seems a shame to do all that to a survivor. If the '67 was rougher and really needed a lot to bring it back, I'd agree to do the mods, but a good running six in a good body is rarer than the 350/350 slammed short fleet. JMO no offense to anyone intended.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
#17 |
http://67-72chevytrucks.com/vboard/s...d.php?t=262961
This link above is to one of the board members trucks that is what i was referring to when i said , "Resto-mod" style . Exterior appears to be nicely restored, yet it is obviously bagged -- wheels are still 6 lug too, which is cool when you compare it to the countless amount of Torq thrust 5 spokers on here. Engine is a slicked out TPI. Your truck would likely be worth more restored in this manner than taken back to a "chalk stripes on the firewall" restoration, because it is a lower optioned model. The higher optioned CST and Cheyenne trucks , as well as the Sierra Grande GMC's are the ones that are worth restoring back to a true stock restoration. Have fun man -- you can get away with a lot more on a resto-mod truck restoration (bags, 20's, etc) than you can a nice mustang or vette restoration (until the money runs out that is) Last edited by streetstar; 10-20-2007 at 07:50 PM. |
#18 | |
Weekend Warrior
I wouldn't put it on a newer chassis either - the factory chassis is great and can be easily and cheaply upgraded for power disc brakes and power steering. as far as the front crossmember goes - I agree with 67_C-30 about rebuilding the front end of a donor truck as well - the only problem is that the '67-'70 Lower front control arms have steering stops that won't work with the disc brake spindles without modifications. You also have to change tie rods as they are different on the '67-'70 compared to the '71-'72 and the '73+. That is why it is easier to get a donor truck. I took all the A-arms from a '91 Suburban, bought some 2" dropped spindles for a '73+ truck, all the steering set-up from a '73+ truck, and bolted all of it to my '69 chassis.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 10-21-2007 at 08:40 PM. |
