Old 10-22-2007, 05:32 PM   #1
jdboy
Question Lug Nuts?
I just got a set of Superior Wheel aluminum mods and when I tried to put them on my truck I found the rear studs only came to about 3/4 way through the lug nut and then when I tried to fit the fronts I only had around 2 threads into the lug nuts. Has anyone else run into this problem trying to mount aluminum wheels with factory lug studs? I first thought that they might need shank style lug nuts but after measuring the hole in the wheel I soon figured out that shank lug nut would never fit. Does anyone know if the big auto parts stores carry longer lug studs?
jdboy is offline   Reply With Quote
Old 10-22-2007, 05:59 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Lug Nuts?
I had to replace my studs on my 67 with longer ones. shank style didnt quite work
1967custom
michael bustamante is offline   Reply With Quote
Old 10-22-2007, 06:28 PM   #3
rodnok1
rodnok1's Avatar
Re: Lug Nuts?
Try Napa,
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
