10-22-2007, 02:39 AM | #1 |
Hooker Header Questions
I have lowered the front of my 71' 3" and the small block long tube headers I've installed are too close to the ground. I've heard there are Hooker headers that work but I don't know which ones.
Does anyone have 3/4 length Chevelle or whatever type of headers installed that work? A part number would be nice too. Thanks.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop |
10-22-2007, 09:24 AM | #2 |
Fabricate till you "puke"
Re: Hooker Header Questions
I have 2452 Hooker comps(painted), on my truck. They hang 2 1/4" below the rails, @ the bottom edge of the collector flange. With a 3/5 drop on my truck, I have no ground clearance issues......if you plan on "slammin" the truck later, you may be better off going to the 3/4 lenght Chevelle headers that some of the crowd is running tho. Good luck,L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-22-2007, 11:40 AM | #3 |
That's right, it's Copper!!
Like this! ECE sells these.
10-22-2007, 03:07 PM | #4 |
its all about the +6 inches
I had the same ones that crazy mentioned, and I loved them. Good high quality item too.
10-22-2007, 03:57 PM | #5 |
67-72 Addict!
Fastom- what pulley setup is that?. Nice! Dingo dan 22- mine are pretty close also. Mine are part #2808
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-22-2007, 04:26 PM | #6 |
It's the March system.
10-22-2007, 04:53 PM | #7 |
67-72 Addict!
Thanks, I'm assuming I could find it on Summitt's website or???
10-22-2007, 05:16 PM | #8 |
I got it from Summit Racing.
10-25-2007, 03:44 AM | #9 |
Anyone run part number 2451?
