Old 10-06-2007, 04:47 PM   #951
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
Re: 58 GMC Project
it's on hold for now, looking to move into a new house with a larger yard to build a larger shop...lol....i'll post pics once i get at her again, but it probably wont be till the new year.
tiggerstoy is offline   Reply With Quote
Old 10-14-2007, 01:42 AM   #952
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Okay, so now that my truck is close to being completed.....well maybe not. I'm giving some serious thought to running dual quads, and a set of Edelbrock Performer RPM aluminum cylinder heads. Also check out these really cool four velocity stack style air filters. I was wish list shopping on-line at Summit Racing's site. Here what I'm looking at. I'm looking at about $2,800.
CAL 58 GMC is offline   Reply With Quote
Old 10-14-2007, 03:13 AM   #953
watahyahknow
watahyahknow's Avatar
Re: 58 GMC Project
looks cool but i would use trottlebodies instead of the carbs to get a little bit more driveabillitie out of it .
will it fit under the hood ?
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-16-2007, 06:26 PM   #954
mylow53
mylow53's Avatar
Re: 58 GMC Project
the last engine builder i spoke to warned me about the aluminum heads on a cast iron block. it's pretty common for the head gasket to go since the aluminum will cool faster than the cast. shredding the headgasket..what do you think about some cast heads?
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 10-16-2007, 06:30 PM   #955
GATORBUILT '59
GATORBUILT '59's Avatar
Re: 58 GMC Project
My 400 has 'Double Hump' cast-iron Camaro heads that are basiclly the samething. But the aluminum heads will help give "the ring in the jewelry box effect"
GATORBUILT '59 is offline   Reply With Quote
Old 10-16-2007, 10:40 PM   #956
pgf545
pgf545's Avatar
Re: 58 GMC Project
You shouldn't have any trouble with head gaskets. Use the Fel Pro ones and I don't see any problems. We ran aluminum heads on our race motors and never had a gasket failure. Also most of the newer motors are aluminum heads on a iron block. Most of the gasket manufactures have solved the expansion problems that used to cause problems in the old days. I say go for it!!!!!!!!!!
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 10-17-2007, 12:01 AM   #957
lotussutol
Re: 58 GMC Project
and I believe with the aluminum heads you will be able to run higher compression too...right?
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
Old 10-17-2007, 01:22 PM   #958
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: 58 GMC Project
yeah, usually a point or so higher
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 10-17-2007, 01:49 PM   #959
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
I'm really don't want the cast iron heads for two reasons. One, anytime I can lighten up somthing that will perform, I'll do it. Second, well the looks of the polished aluminum heads is SWEET! But the real reason is performance. The heads I have on right now are stock heads from a 1974 350 and they just don't perform the way I would like.
Old 10-17-2007, 04:30 PM   #960
my67chevytruck
Under Construction
my67chevytruck's Avatar
Thumbs up Re: 58 GMC Project
Nice Truck Cal
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-17-2007, 06:27 PM   #961
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
Re: 58 GMC Project
great combo if you want you can buy the stuff and send it to me and ill test drive it for you i wouldnt be scared of the aluminum the problems of long ago are gone with quality product you should be fine
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 10-19-2007, 12:23 AM   #962
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Old 10-19-2007, 12:24 AM   #963
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Originally Posted by my67chevytruck View Post
Nice Truck Cal
Thanks my67chevytruck and welcome!
Old 10-25-2007, 03:42 AM   #964
skanave
Re: 58 GMC Project
I see how it is! Finish your truck and don't invite me to come help out anymore!
Looks good, I think I may have found a 72 2wd blazer in town that is calling my name!
skanave is offline   Reply With Quote
Old 10-25-2007, 11:24 AM   #965
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
You can have a ride, but your buying the cheeseburgers now!
Old 10-26-2007, 12:42 AM   #966
skanave
Re: 58 GMC Project
you should know by now that i get no cheese!
you give me a ride, ill buy you lunch at fatjacks. deal?
Old 10-26-2007, 06:03 PM   #967
02snoma
02snoma's Avatar
Re: 58 GMC Project
The combo of dual carbs, intake, and heads should give you a substantial power gain. Alot more than you have now! There goes the gas mileage (not that it was good to begin with)
02snoma is offline   Reply With Quote
Old 10-26-2007, 10:08 PM   #968
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
Re: 58 GMC Project
hi cal, sorry to bother, but what was the measurement of the width of the rear-end out of the blazer you used?.....as you see from my post, the budget build im doing might need a more narrow rear end....thanks ...max.
Old 10-26-2007, 10:12 PM   #969
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 58 GMC Project
Hey Max sorry to butt in...
2wd is 58"
4wd is 60"
thats at least 1999 to 2003
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-26-2007, 10:37 PM   #970
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
Re: 58 GMC Project
great!...thanks entourageguy...im sure cal won't mind us bud'ng in just this once...lol..
Old 10-27-2007, 02:58 AM   #971
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
2wd is 58"
4wd is 60"
Brian ...
Brian beat me to it. It's just as he said. 2wd is 58" &
4wd is 60", it does include 1998 also. If I had to do it over, I would have went with the 4 wheel drive.
Old 10-27-2007, 03:02 AM   #972
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
My Dear Son, Christmas & my birthday is coming don't you know!
Old 10-27-2007, 07:22 AM   #973
entourageguy
Yellow truck club
Re: 58 GMC Project
The only other thing is if you are going low as in c-notch the calipers for the disc brakes will hit the box even with the 60" unless you are going to tub the box.
With the 15x7 rally wheels and 235-70 tire I had to use a 2.5" spacer for the wheel to fit.
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 10-27-2007, 06:20 PM   #974
skanave
Re: 58 GMC Project
was that a subtle hint?
Old 10-27-2007, 09:15 PM   #975
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Brian ...
With the 58", the calipers come un next to the stock leaf spring unless you run lowering blocks. I ened up using 2.5 spacers also with 10 inch wide rims. Again, if I were to do it over, I would use the 4wheel drive like you did and no spacers.
