Old 10-25-2007, 11:15 AM   #1
lyrikz
PITbut
lyrikz's Avatar
Disassemble, reassemble.
71 Step side. Can you remove the front end in one piece?? Unbolt the fenders and the inner fenders, then unbolt everything to the front core support, then pull the two fenders, grill, front core support off in one piece???
A friend recommended that i did it that way, but i didnt think that was possible. Is it???
lyrikz is offline   Reply With Quote
Old 10-25-2007, 11:33 AM   #2
Bucky71
Re: Disassemble, reassemble.
Here's the link to the FAQ.
I've never done it
http://67-72chevytrucks.com/vboard/s...d.php?t=194094
Bucky71 is offline   Reply With Quote
Old 10-25-2007, 11:38 AM   #3
lyrikz
PITbut
lyrikz's Avatar
I've never done it
oh faq me i didnt realize there was a faq'n FAQ on this. Faq.
Old 10-25-2007, 11:39 AM   #4
caminokid
Chevy nut
caminokid's Avatar
Yes you can remove the whole front end in one piece.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 10-25-2007, 11:40 AM   #5
lyrikz
PITbut
lyrikz's Avatar
Would you recommend doing it in one piece, or doing it a piece at a time? Just trying to find the best way, get opinions on which direction to head.
Old 10-25-2007, 12:12 PM   #6
lks dcvn
lks dcvn's Avatar
Piece by Piece method - I would use for disassembly for paint, cleaning, or for selling parts or if it was just you and you had nobody else to help you...
1 shot deal - if you wanted to get to the firewall, frame off restore, etc. Having 1 (or 2) folks to help you move this is essential (obviously), and if the bolts are tight - it will help with maintain the integrity of the front end...If I had to do it - I would enlist a pal or two and do it in one shot...
That's just my opinion though. Hope that helps.
Good Luck.
lks dcvn is offline   Reply With Quote
