Tranny crossmember question
does anybody know if this crossmember from performanceonline.com can be used for either an auto or manual trans? It says its for an auto, but I was wondering if the mount is the same for both trans, but with different bolt hole mounting locations??
http://www.performanceonline.com/sto...cat=461&page=1 ![]() Last edited by jlaird; 10-26-2007 at 07:56 AM. |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Tranny crossmember question
Stock manuals mounted to the bell housing up close to the back of the motor, as the autos mounted on the tail of the tranny.
Here is another pic of man mount from another post.
Thanks for the pics!
Early manual trannys (3spds) were short & used the crossmember that was located immediately behind the back of the engine. Later manual trannys (that are longer/heavier) would need the same auto-trans style transmission crossmember to better support the additional length/weight.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-26-2007 at 01:23 PM. |
scoti,
I thought I read something like that. So would the later style manuals use both the crossmembers or just the further back one? |
#7 | |
IIRC, the original truck bellhousings had provisions for the original style man trans c.member that went just behind the block. Aftermarket bellhousings (or those from a HP application) won't have these provisions.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-26-2007 at 02:50 PM. |
dimensionally the 3spd is the same or almost the same as the TH 350 (uses same driveshaft and yoke). There is also a spot on the three speed where a mount could bolt but I don't know if it is in the same place.
#9 | |
I know you can bolt a 4spd up to the bellhousing & not use any trans c.member @ all. But it's going to cause issues sooner or later.
Yeah, a lot of weight cantilevered will put undue stress on the bellhousing. I suspect the opposite to be true of the 3spd with no support at the bellhousing might sag in the middle. I also notice the bellhousings designed for rear xmembers (no provision for the mounts) have deep fins for added strength and a lot if not all are aluminum which saves weight. An older 3 on the tree nova probably had a saginaw with the rear crossmember so getting that bellhousing setup might be a way to go. I know there are some car guys on here too who will know
Bowler Transmissions builds a awsome tubular cross member that works on both
