#26 |
Re: Crank pulleys.
OK my wp pulley dimensions are:
2 13/16" tall 5 13/16" wide GM part #3995646 AH Crank pulley dimensions are: 2 1/16" tall with ps pulley (this dimension will only be about 2" if installed to balancer) 6 3/4" wide Single crank pulley for wp and alt part # 3755820 BC ps pulley part # 3751232 BB
#27 |
Re: Crank pulleys.
Crank pulley and ps pulley seperated.
#28 |
Re: Crank pulleys.
Here was the original alt. brackets. They bolt to the driver's side head. Is this what you have?
The cast bracket part # is: 3951357 12
#29 | |
Sierra Grande Club
Re: Crank pulleys.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#30 | |
Sierra Grande Club
Re: Crank pulleys.
Thanks for the pictures Matt. I’ll check the other pulleys when I get home. I can quite make out if the pulley is 5/8 form the table I looks like it could be, but the angle is a little off for me to see for sure. The pulley on the bottom is the one that goes against the harmonic balancer? s/t
#31 | |
Sierra Grande Club
Re: Crank pulleys.
s/t
#32 | ||
Re: Crank pulleys.
#33 | |
Sierra Grande Club
Re: Crank pulleys.
If you could put a tape measure against the face of your harmonic B, and tell me what the measurement is to the center of the first belt. (I need 5/8) in one of your pictures it look like it could be...but a mounted measurement will be best. I also checked my water pump pulley. It was within a 1/16 of your measurement. So I think it's ok. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 10-06-2007 at 10:20 AM. Reason: grammar |
#34 |
Re: Crank pulleys.
S/T, sorry I didn't get back to you over the weekend. I was finally able to check the measurement. The distance from the balancer to the center of the first pulley is about 1/2- 5/8". I couldn't tell exactly with the engine in the truck. It's kind of hard to get to with everything on. I hope I've been a help.
Edit- All my pulleys together were probably around $120-140ish. I bought them with other stuff, so I don't know the exact price. Did Summit want $100 a peice or for a set?
#35 |
Sierra Grande Club
Re: Crank pulleys.
I got another pulley setup (not OEM) and it had the same offset on my truck. So I went down to a guy’s shop that has a few of these trucks around and are all original. One of his trucks was off set like mine, maybe not quite as bad, but still not aligned. The other one was perfect. Is this normal?
s/t
#36 | |
Re: Crank pulleys.
I found a great site at work friday night and saved it to my favorits on my work computer, I can get it and post it later monday night, heres the link that might help... http://www.tdperformance.com/pdfs/66-67-Pulleys.pdf |
#37 |
Sierra Grande Club
Re: Crank pulleys.
Cool, thanks for the link. But I'm wondering if miss alignment is normal for some trucks?
I’ve checked my water pump and its 5 5/8 in. & the new pump is the same. All the pulleys are mounted flush with the harmonic balancer and the harmonic balancers are the same. I suspect the one I took off is original too. Is this why they make spacers? Is this a known problem? s/t
#38 |
Re: Crank pulleys.
All I can think of is that possibly you have a balancer or pulley(s) off of different year trucks... That link I have at work list all the pulleys and there spec's that Gm has made.
#39 |
Sierra Grande Club
Re: Crank pulleys.
post it up on Monday..
Thanks, s/t
#40 |
Re: Crank pulleys.
67CRN is right....the one I have has two pulleys, then a spacer and then a third pulley. That said my alt is off a bit and it makes it squeal...gotta fix that someday.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#41 |
Re: Crank pulleys.
S/T, are your wp and alt. pulleys still misaligned? Is anythimg aligned at all? I'm not sure you can shim the crank pulley, but I know you can buy wp pulley shims. Do you have any pics of your system installed? If we could see everything you have as a whole we could probably help more.
#42 |
Re: Crank pulleys.
Stepbed, do you have/know GM part #s for the 3-groove setup? I just got my Vintage Ait unit, and I have the exact factory-style setup you had. It looks like I need another pulley on the crank between the existing two crank pulleys. is my situation an add-on single pulley between, or do I need a double-groove pulley and then use the original single add-on pulley?
Thanks!
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
#43 |
Re: Crank pulleys.
cstanley, I don't know the part #. You need a 2-groove with the add on ps pulley. Mine is just a single groove with the add on.
My new aluminum pulley is one peice with three grooves.
#44 | |
Sierra Grande Club
Re: Crank pulleys.
The yard I got mine from has more, but are a little spendy at $25 a piece. I’m considering taking mine back and using the one that was on my truck with a spacer. s/t
#45 |
Sierra Grande Club
Re: Crank pulleys.
I got all the factory pulley combinations mentioned above and still have the problem. So a shim is in order to space the pulley out a little from the harmonic balancer. (Summit sells them). But I wanted to make sure I didn’t have something else wrong. And after looking at another stock truck with the same problem (the owner didn’t notice it before) I’m convinced this is a common problem that probably goes unnoticed at times.
I want to thanks everyone for there suggestions & ideas. It made for some great discussion and will be helpful with someone else that runs into this problem. I'll post some final pictures when I get my engine completed & installed in the truck. s/t
