![]() Join Date: Jul 2001
Tach Dash F/S - Ks
Have a nice wood grain tach dash for sale. Original GM dash, still has mfg. sticker on it. Back tin has NO rust, needles have some fade, factory printed circut with no cracks or repairs. Date still legible on circut board. Some wear on outer edge of bezel but NO cracks or broken screw holes. All dash lights present with one being for a fiber optic but the line was cut. Hooked the tach up and it does work. Small amount of woodgrain overlay loose near H/L switch but mounted switch will cover. No pics now but later tonight when get home from work. $350 shipped UPS insured. Reply in thread please.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Re: Tach Dash F/S - Ks
First set of pics of woodgrain dash.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 11-02-2008 at 10:00 PM. |
More Pics of Dash
Is it for a 6 cylinder or 8?
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
Honestly can't say, I've looked at the back of the tach and there are some faded stamped numbers or letters (can't tell ) but no idea. Anyway to tell for sure? Adjustment hole has what looks like a sticker that has been removed.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 10-26-2007 at 05:26 PM. Reason: Added info. |
"GO DAWGS"
You may have to remove the printed circuit board and look very closely in the light and it will say 8 cyl or 6 cyl.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
I removed the printed circut board and still cannot read the markings under it. The stampings are pretty faintly marked. Looks like it is a 6 digit number but it is to faint to be legible. Any ideas ?
![]() Join Date: Sep 2006
8 CYL will be stamped on the back of the tach for a V8. 6 cyclinder tachs have no markings. Good luck
70 Custom/10, 396, Muncie 4spd, SWB SOLD 72 Cheyenne K20, 350, Granny 4spd, LWB, daily driver 72 Cheyenne Super C20, 350, Turbo 400, LWB, parts truck for 4WD Cheyenne |
Must be a 6 cyl. tach then. I already removed the circut board and can find no stampings on the tach other then some very faint inked stamped numbers or letters, can't really tell since they are so faint. Dash panel looks to be all original. Did GM use the woodgrain trim with 6 cyl. engines? Figured the woodgrain trim level would be on the upper end Cheyennes and V-8's??
![]() ![]() Join Date: Dec 1999
I know a guy who has a 71 Cheyenne with a factory 6 cyl. I checked the vin myself. So anything goes.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
![]() Join Date: Jan 2005
The 8CYL is usually stamped in the lower left, opposite the 12V stamp - I think
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
Sounds as if the dash I have is in fact a 6 cyl. tach. If I'm to high on the price let me know, need to raise some $$$ for current project.
its all about the +6 inches
whell, when you hooked up the tach to your engine, was it reading accurate, or did it seem to be way off?
Yeah, I had a 6 cyl tach hooked up to my V8 and it definitely read higher. As in, it was easy to peg it at 5,000
#15 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
I was pretty sure that the 6 cyl tachs looked different than the v8 tachs. To me this exactly like a v8 tach. I thought the 6 cyl didn't have so many numbers on them??? Anyone chime in? Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#16 |
Here's a pic of the 6 cyl tach I mentioned earlier. Looks exactly the same from what I can see.
#17 |
"Trucks with Class"
I have a 6 cyl tach and it is stamped in faint black ink on the back...just like the 8 cyl. So you may have either one.
You should hook it up to a running truck, so you will know. This will also make the buyers feel better if they know it actually works. |
#18 |
Okay, after some more research in the 6 cyl vrs. 8 cyl tach question I have come to the conclusion that I indeed do have a 8 cyl. tach. I hooked the tach in question to my running '71 4x4 with what I do know is an 8 cyl. tach in the dash. The tach registered within 25 rpm of my own truck which I would think is a pretty respectable variation. The needle responds well when you jab the throttle. Perhaps I need to make a new thread with new information. If the $350 shipped is to high let me know, I can flex some.
