Old 10-29-2007, 04:43 PM   #1
paul5663
paul5663's Avatar
Window problems w/ my 59
Anyone ever replace sideglass using original steel framing? I am attempting it however, the rubber seal I recieved to replace the old stuff between the glass and the steel frame is way too thick. I ordered both glass and the seal from LMC. They say its the right seal but its not working even using lube on it. I then ordered the seal from Brothers and am having the same problem and it looks like the same stuff. Anybody???????
Thanks.....Paul
http://67-72chevytrucks.com/vboard/s...d.php?t=229882
paul5663 is offline   Reply With Quote
Old 10-29-2007, 08:51 PM   #2
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
Re: Window problems w/ my 59
Thanks.....Paul
it's not the easiest thing to do, but it will work out for you, i use everyday oil....10/30, and so on, use a rubber hammer, LOTS of oil, and slowly work in in, once it dries it's there for life....dont give up, make it work, lots of oil is the trick.....if all else fails, i'v used an old iner tube of a tire, it works just as good.....max.
tiggerstoy is offline   Reply With Quote
Old 10-30-2007, 09:28 AM   #3
paul5663
paul5663's Avatar
Thanks Max.....I'll give that a try.
Old 10-31-2007, 09:03 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
One of the best lubes for rubber I have used is lamb fat from the butcher shop. They call it mutton tallow. warm it up to liquid and then brush it on the area you want to slide together. I'd be surprised if you even had to tap it in. I learned that changing tandem bushings in Mack trucks. The nice part is it washes off with soap and water.
Old 11-01-2007, 12:43 PM   #5
55dude
55dude's Avatar
dishwashing soap works great. tire mounting lube also works great. hit your local tire shop up for some.
55dude is offline   Reply With Quote
Old 11-01-2007, 06:34 PM   #6
paul5663
paul5663's Avatar
Thanks alot for the advice gents, I'm bound to get these windows together for sure now. I bent one of the frames pounding on it w/ a rubber hammer, luckily, I gotta spare window with its frame in the basement somewhere. Thanks again! Paul
