Window problems w/ my 59
Anyone ever replace sideglass using original steel framing? I am attempting it however, the rubber seal I recieved to replace the old stuff between the glass and the steel frame is way too thick. I ordered both glass and the seal from LMC. They say its the right seal but its not working even using lube on it. I then ordered the seal from Brothers and am having the same problem and it looks like the same stuff.
![]() Thanks.....Paul http://67-72chevytrucks.com/vboard/s...d.php?t=229882 |
#2 | |
tiggerstoy
Re: Window problems w/ my 59
Thanks Max.....I'll give that a try.
Hollister Road Co.
One of the best lubes for rubber I have used is lamb fat from the butcher shop. They call it mutton tallow. warm it up to liquid and then brush it on the area you want to slide together. I'd be surprised if you even had to tap it in. I learned that changing tandem bushings in Mack trucks. The nice part is it washes off with soap and water.
dishwashing soap works great. tire mounting lube also works great. hit your local tire shop up for some.
Thanks alot for the advice gents, I'm bound to get these windows together for sure now. I bent one of the frames pounding on it w/ a rubber hammer, luckily, I gotta spare window with its frame in the basement somewhere. Thanks again! Paul
