Re: New style rear axle?
so, are you saying they are a close enough fit (in length) to work?
Correct, they fit fine.
FirstGen spring perches are set inword about 1.5" from the location of a 73up 14ff. My 2005 Duramax has rear disk on it's 14ff. I could measure it but I would guess the spring perch is too wide for a 'bolt in" affair. I do belive the axel length is the same still but I am guessing...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#4 | |
There's always going to be custom work needed when you change em up. |
