11-02-2007, 03:30 PM | #1 |
88' Bench in a 72. info and pics?
ANyone know if it will bolt right up? i can get a free one , but i want to know if it works first. i have 66 impala buckets in there right now, but im pretty sure they bolted right up to the original holes. any info or even pics of late model bench seats in these old trucks.
thanks in advance |
11-02-2007, 03:51 PM | #2 |
Re: 88' Bench in a 72. info and pics?
Those sits fit the cab nicely but you will have to drill some new holes.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
11-02-2007, 04:13 PM | #3 |
thanks a lot man. i appreciate it
11-02-2007, 05:29 PM | #4 |
the front 2 bolt holes will work, you will have to drill 2 new holes for the rear.i have an early '90's bench seat in mine, it works great....
11-02-2007, 05:34 PM | #5 |
Junior Member
I put a 60/40 bench seat out of a '92 GMC into a '72 Chevy pickup and it fit great, but like said before I had to drill a few holes.
Danny - Southeast Missouri |
11-02-2007, 05:43 PM | #6 |
you probably mean '88, not 88' - that's an 88 foot long seat. Not sure if that would fit.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
11-02-2007, 06:01 PM | #8 |
they fit good . you have to drill the rear holes , and i used 1/4 plate to lift the rear up a little .also be sure to put a plate of some sort underneath to strengthen the floor
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
11-02-2007, 07:26 PM | #9 |
Old member
I installed the 60-40 out of a late model 80's truck and had to redrill the holes. I put a 1/2" flat bar under the truck for stiffness. I installed the shoulder harness seat belts also out of the same truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-02-2007, 07:47 PM | #10 |
Heres mine. If I had to do it again, I think I would section about 2 inches out of the seat bracket to lower it a little. Other than drilling 2 holes, it fit perfect.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
11-02-2007, 08:07 PM | #11 |
Moderator
Here's mine:
[IMG][/IMG]
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-02-2007, 08:22 PM | #12 |
yeah they actually look pretty good. since i have the gas tank behind me i want something that doesnt have as much cushion
11-02-2007, 09:52 PM | #13 |
I had a 91 Chevy 1/2 ton truck, I loved those seats! The truck too.
11-02-2007, 10:30 PM | #14 |
Here's mine, but I shortened the brackets to get the seat back just below the rear window and I drilled all new holes cuz I wanted my brackets behind the raised portion of the floor where front mount of the factory seat bolts to.
11-02-2007, 10:38 PM | #15 |
Here's mine, same as most others, I used the front 2 holes, and drilled 2 for the back. I like it the way it is, since the front is a little higher, it helps with the angle of the knees.
Of all the older chevy truck seats out there, these seem to hold up the best based on others I've seen in the junk yard. |
11-02-2007, 10:38 PM | #16 |
are these seat friendly for a 6'5" guy?
11-02-2007, 10:43 PM | #17 |
11-02-2007, 10:50 PM | #18 |
thank u for the info cause the seat in my truck is brokin so ive been lookin for a seat
11-03-2007, 06:52 AM | #19 |
67-72 Addict!
Are any of you guys running the stock gas tank behind that seat????
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-03-2007, 06:56 AM | #20 |
yep !
11-03-2007, 09:39 AM | #21 |
11-03-2007, 09:45 AM | #22 |
here's mine - I cut the bracket down 1-1/2" - I'm 6' and it was a little high with the stock height.
11-03-2007, 09:48 AM | #23 |
Texas Big Wig
I'm 6' 3"
If I would have left it in there, I'd a cut it down about 3" (pretty sure you can't get em much lower) I have the 88-98 buckets in there now & if I leave em in there, I'll prolly cut them down But if you wanna sit really low & look like a midget even though you're really tall, put a 240Z seat on the floor !!!! I did that for about 4 days & I pulled up at walmart & some kid was staring at me, then I walked by em & said "not so short am I"... Ha Ha Ha Ha Ha Ha Last edited by Spray-Bomb; 11-03-2007 at 10:00 AM. |
11-03-2007, 01:18 PM | #24 |
yessir I am
1967custom |
11-03-2007, 02:45 PM | #25 |
I'm 6'2", and I think if I made mine lower to the ground, legroom would get worse.
