Old 11-02-2007, 09:41 PM   #1
Ace in the hole
Speedometer adjustment
Is there any way to adjust the speedometer in 4x4 trucks for different size tires or gearing changes?
Got my NP205 transfer case apart and was looking at the speedo drive gear and it got me wondering about how accurate the speedometer will read when I go to larger tires.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 11-03-2007, 12:40 AM   #2
earl87gta
earl87gta's Avatar
Re: Speedometer adjustment
you have to change the speedo drive gears you should be able to go to napa and get a set.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-03-2007, 07:34 AM   #3
Ace in the hole
That's good to know. How do you figure out what you need though?
Old 11-03-2007, 09:24 AM   #4
earl87gta
earl87gta's Avatar
I know there are calculators out there for it but I dont have one handy.
Earl
Old 11-04-2007, 02:22 AM   #5
Wreckless_71
Wreckless_71's Avatar
I'm preretty sure... in fact I know that there is such thing as an inline ratio changer. instead of changing the gears on the inside of the t-case this miniture gear box screws into your T-case and your speedo cable screws into that. I can get pics if you need...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 11-04-2007, 06:57 AM   #6
Ace in the hole
cool, I went ahead and put my xfer case back together for now but an inline adapter would be cool. where do you find them?
Old 11-04-2007, 07:59 AM   #7
Billla
Billla's Avatar
http://www.tciauto.com/Products/Tech...eedo_gears.asp
Billla is offline   Reply With Quote
Old 11-04-2007, 09:32 AM   #8
Ace in the hole
I see speedo gears for automatics on that site but how about manuals?
