Old 11-04-2007, 11:17 PM   #1
48 ish
48 ish's Avatar
"Dually" Noted
Just finished my big block install and am ready to start working on the dually conversion, would like to hear from anyone thats already done one ,or has one and can pass on some pearls of wisdom....I've measued axels from 44" to 59" backing plate to backing plate, any prefs on the width? What is the general gear ratio's on the dually's? And how expensive is it to change the ratio? What about fenders? Have had thoughts about using step side fenders and trim them to fit, or using a late model dually bed, any prefs?
hooberjon@yahoo.com
"Life's Been Good To Me So Far"
1941 Chevy PU (new project, right out of the field)
1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor
1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console.
1996 Geo Tracker 2x4
1996 Geo Tracker 4x4
48 ish is offline   Reply With Quote
Old 11-04-2007, 11:26 PM   #2
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Re: "Dually" Noted
You May want To Check This Thread Out, He has Done a Good Job & Goes in Depth on How to Use Stepper Fenders...........
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
Good Luck With Your Project, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 11-04-2007, 11:35 PM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: "Dually" Noted
Thanks toomanytoyz! The rearend I'm using is out of a '97 C3500, and it measures 90" from outside to outside. I'll measure from backing plate to backing plate for you tomorrow. I'm running 4.10's in mine, and I am going with a 6.5L Turbo Diesel. Making the fenders was much easier than I thought they would be. Feel free to PM with any questions or concerns about doing them. I bought a set of bigger, wider tires for it today. I'm hoping it will bring the outside of the dual tires closer to the wheelwell. If not, I'm probably going to shave about an inch off of the stepside fenders. I'll keep you posted on that. I'm still also trying to decide if I want to droip the rear or raise the front to even out the stance.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-05-2007, 02:31 AM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: "Dually" Noted
Truck is looking good 67 C-30!
Old 11-05-2007, 02:46 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
Re: "Dually" Noted
I love 67-72 dually conversions
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 11-05-2007, 08:14 AM   #6
Re: "Dually" Noted
It does look right.
Old 11-05-2007, 10:32 AM   #7
shaneschevys
Its always something!
shaneschevys's Avatar
Re: "Dually" Noted
Thats a clean old truck. Its going to look good.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 11-05-2007, 11:00 AM   #8
67_C-30
67_C-30's Avatar
Re: "Dually" Noted
Thanks for the kind words guys. I went out today and measured the rearend for you. It is 58" plate to plate. If you are happy with your current ratio, there are companys out there that sell dual rear wheel adapters. It may save you money and fabrication if you have to buy a rearend weld mounts to make it fitn like I did. My original rearend had 5.38 gears, so I would have had to change everthing. Don't be afraid of the billet adapters. I've been running a set on my '69 C-30 car for years with weights higher than you could ever put on a pickup and they are rock solid. Here are a few places to get them.
http://www.wheeladapter.com/DuallyAdapters.asp
http://www.arrowcraft.com/
My trucks
Old 11-05-2007, 01:01 PM   #9
1969 GMC
1969 GMC's Avatar
Re: "Dually" Noted
If you are using the original eaton rearend under your truck, swapping ratios couldn't be easier. Just buy another center section with the gears you want, and bolt it in. Downside is you are fairly limited with your selection; only 4.11, 4.57, and 5.14 are the most widely available oem ratios. However, depending on what you are doing with the truck, I think the 4.11's would work well for you, and keep it streetable.
That is a nice looking job on that truck. Are you going to shave one of the rear marker lights? I'd leave just one on the actual fender itself.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-05-2007, 01:24 PM   #10
67_C-30
67_C-30's Avatar
Re: "Dually" Noted
Since it's a '67, I am going to shave both the one on the fleetside bed and the stepside fender. I am going to come back put some kind of small markers on the stepside so I can see them at night. I just think the factory markers look too big and gauky to be clearance lights. I have a set of lights from the '97 C3500 I got my rearend from. I may put them in right below the body ridge which is about the same location as the they came on the '88 - '98 trucks like in the pic below.
My trucks
Old 11-05-2007, 01:40 PM   #11
67_C-30
67_C-30's Avatar
Re: "Dually" Noted
This is what I have in mind...
My trucks
Old 11-05-2007, 02:04 PM   #12
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: "Dually" Noted
67 C-30 thats one fine truck... i cant wait to see it all finished great work....
bad6772 is offline   Reply With Quote
Old 11-05-2007, 02:23 PM   #13
1969 GMC
1969 GMC's Avatar
Re: "Dually" Noted
i gotta hand it to you, that will look great. again, AWESOME truck!
1969 GMC K2500
1996 Honda Accord
Old 11-06-2007, 01:11 AM   #14
48 ish
48 ish's Avatar
Re: "Dually" Noted
67_C-30- Thanks for all the help, had seen the dually converters in JC Whitney but didn't take them serious. I'll givee them another look. I'm running 4.11's now, was thinking more like 3.90 since I have the Gear Vendor aux. I have a couple of "before" pics I'll post if I can figure out how. Thanks again for all your help, your a gold mine
hooberjon@yahoo.com
Old 11-06-2007, 01:25 AM   #15
48 ish
48 ish's Avatar
Re: "Dually" Noted
Figured out how to load these pics, everthing is "before" except the egine shot. Thats a new 427 Tall Deck. Am working on painting the cab and front end this week, will do the bed when I figure out how I'm going to do the dually....
hooberjon@yahoo.com
Old 11-06-2007, 02:36 AM   #16
48 ish
48 ish's Avatar
Re: "Dually" Noted
Two more
hooberjon@yahoo.com
Old 11-06-2007, 10:41 AM   #17
toomanytoyz
Luv the Crewcabs
Re: "Dually" Noted
That Motor look's Awesome the Way You Painted it up, Good Luck with your Project.....
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 11-06-2007, 07:02 PM   #18
67_C-30
67_C-30's Avatar
Re: "Dually" Noted
48ish - that truck will look great in dually form! It should be hoss with the 427 tall deck and GV OD!
My trucks
Old 11-07-2007, 12:31 AM   #19
48 ish
48 ish's Avatar
Re: "Dually" Noted
Thanks guys...I just finished painting the front end tonight, I'll be sure to post more pics when I get all the bits and pieces back on. I got a good deal on a set of dually wheels (all 6) for $150, and looked at the adapters, I'm thinking I might go that route .
67_C30...how did you end up marrying the fenders to the bed? screws? bolts? what size/type? or did you weld them? ..
hooberjon@yahoo.com
Old 11-07-2007, 04:04 PM   #20
Dieselwrencher
Re: "Dually" Noted
Lookin good!
Old 11-08-2007, 08:27 AM   #21
67_C-30
67_C-30's Avatar
Re: "Dually" Noted
I welded tabs to the backside and drilled hole in the fleet bedside and bolted them on with (10) 5/6 - 18 bolts. The tabs are actually part of the stepside fender that I cut to contour it to the fleet bedside. There's a lot more pics and details on my build thread in my sig.
My trucks
Old 11-09-2007, 10:57 PM   #22
48 ish
48 ish's Avatar
Re: "Dually" Noted
Isn't the bed side double walled? How did you attatch the nuts?
hooberjon@yahoo.com
