Old 05-16-2002, 03:12 PM   #1
68 Suburban
68 Suburban's Avatar
Post Setting Timing?
Which way do you turn the distributor to retard and advance the timing?
Check out other members trucks
1968 50th Anniversary C-10 Suburban (Tows all these cars all over the place)
1968 50th Anniversary C-20 Pickup CST, Sold to Fine69
1969 SS Camaro Conv't
1960 Lakewood Travel Trailer
1963 Ford Falcon Wagon, Still For Sale
Phoenix, AZ.
Click Here for Parts and Venicles I have Available
THINGS I AM LOOKING FOR:
67-68 SUBURBAN TRIM. $$$$ Reward
for finding the 3rd door trim piece
and the small piece that goes on
the 1/4 panel right behind the
3rd door.
Click Here to see the two pieces I need.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-16-2002, 03:17 PM   #2
tom hand
CCRider
tom hand's Avatar
Post
Oh you are really testing my memory. I'll guess and if I am wrong it will take two seconds for someone to correct me. CCW advances,CW retards. Then put the fuel that you plan to run,advance the timing till it pings,and back it off just enough to make it quit pinging. That is what chevy's like.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-16-2002, 03:17 PM   #3
bigvinnie
bigvinnie's Avatar
Post
sounds like you're trying to do it without a timing light or you can't find your timing marks...?? If you're doing it by ear, rpms will increase as advance increases.. good luck
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-16-2002, 03:23 PM   #4
mtdave2
newly minted old timer
mtdave2's Avatar
Post
tom is right.. just keep bumping it ccw untill she rattles under power. then back it off a bit cw.
under power means get on the street and accelerat hard.. if you here a rattle thats too far. i have gotten as much as 19btdc before on a engine with a large cam..
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 05-16-2002, 04:20 PM   #5
tom hand
CCRider
tom hand's Avatar
Post
I am a cheapskate, I time it that way because it gets better gas milage, LOL
Olive Branch MS
Olive Branch MS
Old 05-16-2002, 04:25 PM   #6
68 Suburban
Post
Are there any starting symptoms of an engine that is too far advanced or too far retarded? Sometime my engine sounds like it is strugling to start.
Phoenix, AZ.
3rd door.
Old 05-16-2002, 04:32 PM   #7
mtdave2
mtdave2's Avatar
Post
ya, if you are to far it will hesitate and make a strange noise when starting..
69 k10 Suburban
Old 05-16-2002, 04:43 PM   #8
tom hand
CCRider
tom hand's Avatar
Post
Yes, if it is too far advanced it will be hard on the starter. A quick way to check is to dissconnect the ignition. If you have an HEI unplug the power wire, if you have points remove the coil wire. Now try to crank it,if it turns over faster retard the timing.
Olive Branch MS
[This message has been edited by tom hand (edited May 16, 2002).]
Olive Branch MS
Old 05-16-2002, 04:51 PM   #9
Scrub
Collector of rusty Items
Scrub's Avatar
Post
Retard and advance always foul me up.
If you turn it clockwise, the spark will fire later in the compression stroke. That is what you need to do if it starts hard. My starter got worn and the dang thing would not start hot. Every time I shut it off hot, I had to pop the hood and rotate the distributor clockwise a bit, Start the engine and then jump back out and turn it back.
You can time your engine by setting the motor to where it is sitting with the timing mark at say 8 degrees before top dead center. Turn the key on, but don't start the motor. Now rotate the distributor clockwise a bit and roll it back ccw real slow. If you listen hard, you can hear the points snap open. You will have to pop the cap to hear it. You are now rough timed.
Then fiddle with it a bit until it is perfect by rolling it ccw until it either starts hard or pings a bit. Be carefull as a motor that is too far ccw can run real hot and actually melt a piston.
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
