Old 10-30-2007, 11:11 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Power steering bracket.
I was installing my power steering bracket and noticed this gap at the motor mount. It appears that it needs a roll pin (like what is on the alternator bracket). Does anyone know what I need? I’m pretty sure it the correct bracket. Any help would be appreciated.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-30-2007, 11:13 PM   #2
corn
Re: Power steering bracket.
Theres supposed to be a small spacer in there. I may have one somewhere. Ill let you know if I find it...
corn is offline   Reply With Quote
Old 10-30-2007, 11:18 PM   #3
Sport/Truck
Sierra Grande Club
Thanks!!! I don't know what I'm looking for!
s/t
Old 10-30-2007, 11:19 PM   #4
corn
Now that I think about it, its supposed to be a stud in there isnt it?
Old 10-31-2007, 04:56 AM   #5
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
hmm, all mine has is the motor mount bolt going thru it. Or it would have if I hadn't forgotten to have put it in there...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-31-2007, 07:03 AM   #6
Sport/Truck
Sierra Grande Club
Correct, a bolt does go through the bracket & motor mount. But it appears to need some type of spacer to fill the 3/16 gap. Since this is cast, you can’t just tighten it down, or it could break. I think the piece is similar to what is used on the alternator brackets, but I don’t know. If anyone has a picture of one please post it.
s/t
Old 10-31-2007, 12:36 PM   #7
Sport/Truck
Sierra Grande Club
I’m thinking now it might be a stud that goes there (the head of the stud fills the gap). Anyone have information on this??
s/t
Old 10-31-2007, 08:21 PM   #8
Sport/Truck
Sierra Grande Club
I went to a guys shop here in town to look what might be missing from my brackets. And it appears that I have something completely different. Can someone confirm this? What do I need?
I’m going to look at aftermarket brackets too, so I can raise the pump a little (if I can).
Thanks for the help.
s/t
Old 11-02-2007, 08:04 PM   #9
mbgmike
We sell the spacer for the 1969 camaro bracket. The truck may be the same. Its .40 id .25 thk and .730 od.
We sell all kinds of "CORRECT" GM rubber, clips ,wire ties, tape, retainers, small carb linkage clips etc. that are really hard to find, even rivets that are correct.
Mike
mbgmike is offline   Reply With Quote
Old 11-05-2007, 06:17 PM   #10
Sport/Truck
Sierra Grande Club
Here are better pictures (still a cell phone camera) but shows more of the bracket. I’m not sure what this bracket is off of, but it appears that it will work. I’m going to use a stud in the block to hold the motor mount, and nut for the brackets arm (see post #1 with arrow).
I set the pump in and checked my pulley alignment, without all my bolts in the pump it appears it will be fine. (I’m going to get a pulley puller and double check tonight).
This bracket doesn’t use the old adjustment bracket that is mounted on the pump (see picture). Instead it uses the bolt hole (unpainted bolt hole in picture) on the back of the pump.
I’m not sure if it sets flat against the bracket there or if I need to use a stud. (Again I’ll test fit when I get the pulley puller).
If anyone knows what this bracket is off of & how this pump is supposed to be mounted LET ME KNOW!! (I’m just guessing!!) (I do know it’s not original 71-72)
If I can find out what it’s off of, then I’ll be able to look it up by application to see how it mounts.
Summit sells an adjustable mount for 75 bones, but not sure where the turn buckles gets mounted (possibly the water pump). But it’s billet and will need the black powder coated!! Lol.
s/t
Old 11-05-2007, 10:21 PM   #11
Sport/Truck
Sierra Grande Club
anyone know if this is the correct bracket??
s/t
Old 11-06-2007, 06:06 AM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, that is the correct bracket. There were two types used on these trucks, the cast one like you have (the better of the two) and the plate steel one (often cracked).
Put two 3/8 washers in that gap and go on to work on something else. If you're feeling particularly obsessive/ compulsive, paint the washers black to make them blend in. No fancy spacer needed.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
