Old 11-06-2007, 05:41 PM   #1
babyblueoval
babyblueoval's Avatar
Re: How to: Ruin a perfectly good Blazer...
Hey Chris,
While you've got your truck torn apart you should put that early front cap on there then your truck would be absolutely perfect.
When I finish mime, our trucks could be twinkies except for the color... and the interior.... and the engine....and the trans.....and....and.
Ok so maybe not twinkies but when I come to visit and we go down a few at Superior we'll certianly draw some attention.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 11-08-2007, 12:59 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
It's definitely in the cards, but bodywork/paint is down on the list a few notches. I have a '70 pickup that is sorely neglected and in need of some attention too once this little project is done...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-09-2007, 09:55 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Made a little progress tonite- finally. Before I started welding, I spent some time setting up a dedicated 20A circuit to feed the welder. The first pic is my test piece. I wanted to make sure I was getting good penetration, plus it has been a while since I laid a bead. I think It will work...
I got the outer plates tacked, well actually, stitched in. Besides just running a bead around the perimeter, I also did a few plug welds in the existing holes in the frame for some insurance.
After I got them where I wanted them, I marked the excess....
-Chris
Old 11-09-2007, 10:07 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
...and lopped it off with a cut-off wheel. You can see that I made the cut a little bit above the bottom of the frame so that when I run the bead there, it will not be an overhead weld. I HATE overhead welding...
Everything so far is going well and it all ended up level and symmetrical. Guess all the obsessive measuring is paying off. The front to back is not level- it is parallel with the frame. When I set the jackstands I had about 1/8 bubble on the top of the frame rails and that is where I set the notches. Side-to- side and up-and-down they are level and plumb.
-Chris
Old 11-11-2007, 07:28 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Since the rear seat will be attached directly to the floor, and I have lost some of the rigidity by removing a large portion of it, I decided that I would mount the notch cover directly to the notches. To do this, I drilled a couple of holes in line with the recesses in the floor and welded nuts inside the top plate of the notch. I will use grade 8 hardware and rubber mounting pads from a truck bed for a little NVH isolation. I didn't get far before the shop foreman stepped in and shut me down...
-Chris
Old 11-14-2007, 11:57 AM   #6
grnddwn
belly dragger
grnddwn's Avatar
I build a whole new frame for my floor and mounted the seat to it. I found that the floor still flexed a little too much even with notch cover. I didn't think of attaching it to the frame though, and minewas in being bodydropped 2" anyway.
Truck looks sweet.
SAVE THE PLANET DRIVE AN OLD TRUCK
grnddwn is offline   Reply With Quote
