Old 11-05-2007, 06:21 PM   #1
humanspeeddemon
Question 3 speed to th350 swap?
Hi, Ive got a 3 speed and I want to convert it to a th350. Ive got the trans but can anyone tell me what else i need.Ive found a rear trans crossmember but thats all ive found. Any advice would help me .thanks.
humanspeeddemon is offline   Reply With Quote
Old 11-05-2007, 07:03 PM   #2
nplocoman
never finish start another
nplocoman's Avatar
Re: 3 speed to th350 swap?
Steering column all linkages and drive shaft and a flexplate. Those are a good start!
nplocoman is offline   Reply With Quote
Old 11-05-2007, 07:10 PM   #3
ante_up13
convert from a 3 speed to a 3 speed?
ante_up13 is offline   Reply With Quote
Old 11-05-2007, 08:12 PM   #4
humanspeeddemon
I know its sorta assinine but its all i have in a pinch. Im just trying to get through the winter as cheaply as possable.
Anyway I have flexplate,torque converter,trans,kickdown cable,and the drive shaft is a stock 2 piece.
did thay ever install a th350 and is the driveshaft different thay my man 3 speed?
Old 11-06-2007, 07:45 PM   #5
nplocoman
nplocoman's Avatar
You have a good start. I think that the drive line is a different length. The section from the rear of the auto is different from the 3 sp.
Old 11-06-2007, 08:20 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Starter nosecone and starter mounting bolts too, or a different starter if you're not comfortable taking your old starter apart to swap the nosecone.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-06-2007, 08:24 PM   #7
Cyclone44
Step Brother
Cyclone44's Avatar
The Radiator is different too......George
Cyclone44 is offline   Reply With Quote
Old 11-06-2007, 08:33 PM   #8
1969k10stepside
Or just get a aftermarket tranny cooler like I did...dont forget the tranny cooler lines.You need the column,linkages,frame bracket,tranny,crossmember I believe,driveshaft maybe,flexplate,torque convertor,starter,aftermarket cooler or swap to a auto tranny style radiator,tranny cooler lines...I think that is most of everything.I have most of the parts you need down here,but that's a pretty good drive from where you are.
1969k10stepside is offline   Reply With Quote
Old 11-07-2007, 12:20 AM   #9
ante_up13
I was just curious...hey, whatever you need to do to keep that rig on the road! Good luck!
Old 11-07-2007, 01:03 AM   #10
WorkinLonghorn
WorkinLonghorn's Avatar
Modulator line.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 11-07-2007, 10:55 AM   #11
chris71
chris71's Avatar
if you are on a budget and in a jam, i would probably got to a yard and try to find all this stuff for a 67-72 truck, if not, i would pull some sort of floor shift and linkage from maybe a 82-92 camaro or other car, this would save you from buying a column and linkage. i would even get the modulator vaccum line and trans lines from a yard , if they are the wrong size you can bend them. get as much stuff from the yard as you can if you are in a bind. i would reccomend you try to get the correct 67-72 parts first, as it will be easier to make the swap with less modifictaions and jurry rigging. with the correct stuff, the truck will have a higher resale value as well. whatever you do , good luck
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
